I saw this answer for configuring enabling and being able to use audio but was unsuccessful. I want to have audio to my headphones which are plugged into the 3.5mm jack. I have tried:
- Forcing audio to the headphone Jack
- Making sure I have alsa-utils installed(I asume I do because
aplay
does not give errors; in fact it says it is playing the file I give it!) - I ran
modprobe snd_bcm2835
- I made sure ALSA was starting when the Pi boots
All I hear is sort of white noise coming out of the jack regardless of whether aplay
is running or not. I also made sure that it was a .wav file with these codecs: 22050khz, 16bit, mono, PCM Little Endian if that matters. But regardless of what wav or mp3 I use it does not work. The only noise I can get to work is the sine wave in the hello_world examples folder but with lots of noise. Any suggestions?
service pulseaudio status
says it is running, try,sudo service pulseaudio stop
and see if that helps. You might also have a look atalsamixer
-- on the pi it is just one "PCM" volume; you can turn it up and down w/+
and-
. – goldilocks Jun 02 '15 at 15:55mpg123
) can be built with multiple backends (for pulse and alsa) and may default to pulse. I don't thinkaplay
is like that (but I don't think aplay does anything but PCM, i.e.,.wav
but not.mp3
). Your test sounds fine to me, although you might have a look at the various parameters (man aplay
) to see if setting those manually helps. – goldilocks Jun 04 '15 at 12:24echo 'snd_bcm2835' >> /etc/modules
I was able to get omxplayer to play the wav files and mp3s. I didn't know what it meant put it worked! I haven't tried aplay again yet. Will update when I do. – NULL Jun 04 '15 at 18:18/etc/modules
is a list of things that it will load regardless. By default I think Raspbian does includesnd_bcm2835
in there, andmodprobe snd_bcm2835
should load it...so who knows. You can always double check w/lsmod
, which lists loaded modules. – goldilocks Jun 04 '15 at 19:41
