I have rasbian installed and I'm trying to use LIRC to read from a remote control following this tutorial.
http://mvartan.com/2014/11/25/controlling-your-tv-or-any-ir-device-with-raspberry-pi/
I have successfully created a remote control configuration using irrecord. I have saved the configuration to /etc/lirc/lircd.conf
When I attempt to start the lirc process, I get this error
root@raspberrypi:/opt# /etc/init.d/lirc start --verbose
[ ok ] Loading LIRC modules:.
[FAIL] Unable to load LIRC kernel modules. Verify your ... failed!
[FAIL] selected kernel modules in /etc/lirc/hardware.conf ... failed!
Contents of /etc/modules
snd-bcm2835
lirc_dev
mceusb
lirc_rpi gpio_in_pin=23 gpio_out_pin=22
Contents of /etc/lirc/hardware.conf
# /etc/lirc/hardware.conf
# Arguments which will be used when launching lircd
LIRCD_ARGS=""
#Don't start lircmd even if there seems to be a good config file
#START_LIRCMD=false
#Don't start irexec, even if a good config file seems to exist.
#START_IREXEC=false
#Try to load appropriate kernel modules
LOAD_MODULES=true
# Run "lircd --driver=help" for a list of supported drivers.
DRIVER="default"
# usually /dev/lirc0 is the correct setting for systems using udev
DEVICE="/dev/lirc0"
MODULES="lirc_dev,mceusb"
# Default configuration files for your hardware if any
LIRCD_CONF=""
LIRCMD_CONF=""
Output of lsmod
root@raspberrypi:/opt# lsmod
Module Size Used by
snd_bcm2835 21149 0
snd_pcm 90778 1 snd_bcm2835
snd_seq 61097 0
snd_seq_device 7209 1 snd_seq
snd_timer 23007 2 snd_pcm,snd_seq
snd 66325 5 snd_bcm2835,snd_timer,snd_pcm,snd_seq,snd_seq_device
evdev 11000 2
ir_lirc_codec 5056 0
ir_xmp_decoder 2925 0
lirc_dev 11060 1 ir_lirc_codec
ir_mce_kbd_decoder 4248 0
ir_sharp_decoder 2201 0
ir_sanyo_decoder 2433 0
ir_sony_decoder 2206 0
ir_jvc_decoder 2179 0
ir_rc6_decoder 2755 0
ir_rc5_decoder 2259 0
ir_nec_decoder 2603 0
rc_rc6_mce 1365 0
mceusb 10119 0
rc_core 23526 14 ir_sharp_decoder,ir_xmp_decoder,lirc_dev,ir_lirc_codec,ir_rc5_decoder,ir_nec_decoder,ir_sony_decoder,mceusb,ir_mce_kbd_decoder,ir_jvc_decoder,ir_rc6_decoder,ir_sanyo_decoder,rc_rc6_mce
uio_pdrv_genirq 3666 0
uio 9897 1 uio_pdrv_genirq
The receiver and transmitter that I am using is this one.
I am able to read from remote controls, but not start the lirc service.
How can I get this service to start, and load these modules?
