From my Raspberry Pi 2, I can't connect to my wifi college: sudo ifup wlan0
returns:
ioctl[SIOCSIWAP]: Operation not permitted
ioctl[SIOCSIWENCODEEXT]: Invalid argument
Internet Systems Consortium DHCP Client 4.2.2
Copyright 2004-2011 Internet Systems Consortium.
All rights reserved.
For info, please visit https://www.isc.org/software/dhcp/
Listening on LPF/wlan0/00:0b:81:94:e7:e1
Sending on LPF/wlan0/00:0b:81:94:e7:e1
Sending on Socket/fallback
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 5
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 13
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 8
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 10
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 15
No DHCPOFFERS received.
No working leases in persistent database - sleeping.
Here's lsusb
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp.
Bus 001 Device 004: ID 0bda:8176 Realtek Semiconductor Corp. RTL8188CUS 802.11n WLAN Adapter
And lsmod
8192cu 528429 0
So it seems that my RPi detected my wifi dongle with success.
These are my /etc/network/interfaces
# Loopback network interface
auto lo
iface lo inet loopback
# auto eth0
iface eth0 inet dhcp
auto wlan0
allow-hotplug wlan0
iface wlan0 inet dhcp
pre-up wpa_supplicant -B -Dwext -iwlan0 -c /etc/wpa_supplicant/wpa_supplicant.conf -f /var/log/wpa_supplicant.log
post-down killall -q wpa_supplicant
iface default inet dhcp
And my /etc/wpa_supplicant/wpa_supplicant.conf
update_config=1
network={
ssid="wifiname"
scan_ssid=1
identity="student.name@collegedomain"
# I got this password by using wpa_passphrase ssid mypassword
password="mypassword"
proto=RSN
eap=PEAP
key_mgmt=WPA-EAP
pairwise=CCMP
auth_alg=OPEN
phase2="auth=MSCHAPV2"
iwconfig wlan0
wlan0 unassociated Nickname:"<WIFI@REALTEK>"
Mode:Managed Frequency=2.462 GHz Access Point: Not-Associated
Sensitivity:0/0
Retry:off RTS thr:off Fragment thr:off
Power Management:off
Link Quality:0 Signal level:0 Noise level:0
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:0 Missed beacon:0
ifconfig wlan0
wlan0 Link encap:Ethernet HWaddr 00:0b:81:94:e7:e1
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
If my wifi dongle is detected, maybe I'm mistaken about the configuration.
My college's wifi security is WPA/WPA2, EAP-PEAP, MSCHAPV2.
What am I doing wrong?
Edit 1: added infos about iwconfig wlan0
and ifconfig wlan0
Edit 2: tried to execute ~ $ wpa_supplicant -dd -B -i wlan0 -c /etc/wpa_supplicant/wpa_supplicant.conf
, it says :
wpa_supplicant v1.0
random: Trying to read entropy from /dev/random
Initializing interface 'wlan0' conf '/etc/wpa_supplicant/wpa_supplicant.conf' driver 'default' ctrl_interface 'N/A' bridge 'N/A'
Configuration file '/etc/wpa_supplicant/wpa_supplicant.conf' -> '/etc/wpa_supplicant/wpa_supplicant.conf'
Reading configuration file '/etc/wpa_supplicant/wpa_supplicant.conf'
Failed to read or parse configuration '/etc/wpa_supplicant/wpa_supplicant.conf'.
Failed to add interface wlan0
: Cancelling scan request
: Cancelling authentication timeout
Edit 3: ls -ltr /etc/wpa_supplicant/wpa_supplicant.conf
-rw------- 1 root root 576 Feb 16 22:27 /etc/wpa_supplicant/wpa_supplicant.conf
Edit 4: sudo iwlist wlan0 scan
(you may read something significant which I couldn't get):
wlan0 Scan completed :
Cell 01 - Address: 00:3A:99:48:18:20
Channel:11
Frequency:2.462 GHz (Channel 11)
Quality=66/70 Signal level=-44 dBm
Encryption key:on
ESSID:"ALMAWIFI"
Bit Rates:6 Mb/s; 9 Mb/s; 12 Mb/s; 18 Mb/s; 24 Mb/s
36 Mb/s; 48 Mb/s; 54 Mb/s
Mode:Master
Extra:tsf=0000000000000000
Extra: Last beacon: 12ms ago
IE: Unknown: 0008414C4D4157494649
IE: Unknown: 01088C9298243048606C
IE: Unknown: 03010B
IE: Unknown: 0706495420010D14
IE: Unknown: 0B0503003A8D5B
IE: Unknown: 2A0100
IE: IEEE 802.11i/WPA2 Version 1
Group Cipher : TKIP
Pairwise Ciphers (1) : CCMP
Authentication Suites (1) : 802.1x
IE: Unknown: 7F06001000000040
IE: Unknown: 851E01008F000F00FF03590041502D424F2D3030303030313735310003000027
IE: Unknown: 9606004096000800
IE: WPA Version 1
Group Cipher : TKIP
Pairwise Ciphers (1) : TKIP
IE: Unknown: DD180050F2020101800003A4000027A4000042435E0062322F00
IE: Unknown: DD06004096010104
IE: Unknown: DD050040960305
IE: Unknown: DD050040960B09
IE: Unknown: DD050040961401
Cell 02 - Address: 00:3A:99:2C:5F:40
Channel:11
Quality=28/70 Signal level=-82 dBm
Encryption key:on
ESSID:"ALMAWIFI"
Mode:Master
IE: Unknown: 03010B
IE: Unknown: 0B0503000A8D5B
IE: Unknown: 2A0100
Group Cipher : TKIP
IE: Unknown: 851E04008F000F00FF03590041502D424F2D3030303030313834390003000027
IE: Unknown: 9606004096000B00
IE: WPA Version 1
Group Cipher : TKIP
Cell 05 - Address: 00:3A:99:5C:FF:F0
Channel:1
Frequency:2.412 GHz (Channel 1)
Quality=42/70 Signal level=-68 dBm
Encryption key:on
ESSID:"ALMAWIFI"
Mode:Master
IE: Unknown: 030101
IE: Unknown: 0B050400238D5B
IE: Unknown: 2A0100
Group Cipher : TKIP
IE: Unknown: 851E03008F000F00FF03590041502D424F2D3030303030313830310004000027
IE: WPA Version 1
Group Cipher : TKIP
Edit 5: I forgot to look here; cat /var/log/wpa_supplicant.log
rfkill: Cannot open RFKILL control device
wlan0: Trying to associate with 00:3a:99:48:18:20 (SSID='ALMAWIFI' freq=2462 MHz)
wlan0: Association request to the driver failed
wlan0: CTRL-EVENT-DISCONNECTED bssid=00:3a:99:48:18:20 reason=0
wlan0: Trying to associate with 00:3a:99:5c:ff:f0 (SSID='ALMAWIFI' freq=2412 MHz)
wlan0: CTRL-EVENT-DISCONNECTED bssid=00:3a:99:5c:ff:f0 reason=0
wlan0: Trying to associate with 00:3a:99:2c:5f:40 (SSID='ALMAWIFI' freq=2462 MHz)
wlan0: CTRL-EVENT-DISCONNECTED bssid=00:3a:99:2c:5f:40 reason=0
...and so on, always the same three unsuccessful attempts.
Also: run
– Doug Edey May 13 '15 at 11:16ls -ltr /etc/wpa_supplicant/wpa_supplicant.conf
to check permissionswpa_supplicant
without-B
returns a huge amounts of lines, I could pass them through a pastebin. @ppumkin I want to get it right withwpa_supplicant
:) – elmazzun May 13 '15 at 11:31sudo
and me against the world – elmazzun May 13 '15 at 11:50This isn't a RPi specific question however, you'd be better off in a linux/wifi stackexchange.
– Doug Edey May 13 '15 at 14:48Check here, this sounds like it has a very similar setup to your university.
– Doug Edey May 15 '15 at 01:59
