I'm getting following message inside of wpa_gui:
Status: Could not get status from wpa_supplicant
Last Message: -signal 15 received
What is signal 15? I tried clicking on Disconnect & Connect, but nothing seems to be working for me other then Menu -> Shutdown -> Reboot.
Is there a service I can restart, so I don't have to rebooting my Raspberry?
alexus
  • 327
  • Signal 15 is SIGTERM, but I guess that doesn't help you much. It's a polite way of asking a process to stop, but it can be ignored. Have you tried restarting wpa_gui? You could also try service NetworkManager restart... – goldilocks Apr 06 '15 at 15:51
  • I tried restarting wpa_gui that did not help, but I got new Status: Could not get status from wpa_supplicant, and service NetworkManager restart returns NetworkManager: unrecognized service – alexus Apr 06 '15 at 16:08
  • Sorry -- Raspbian doesn't use that by default and it is probably for the best. How about service networking restart? I can't promise anything but it is worth a try. – goldilocks Apr 06 '15 at 16:12
  • that i tried, however that did not help me resolve my question( (still same Status: Could not get status from wpa_supplicant) – alexus Apr 06 '15 at 16:15
  • Hmmm. In order sudo service networking stop (ignore it if it won't), sudo killall -9 wpa_supplicant, sudo service networking start. – goldilocks Apr 06 '15 at 16:53
  • wpa_supplicant isn't running according to ps output and sudo service networking stop stops networking service without any problem too. – alexus Apr 06 '15 at 18:22
  • Once you have networking stopped, wpa_gui stopped, and there are no wpa_supplicant instances running, try this (you can ignore the beginning bit about NetworkManager). – goldilocks Apr 06 '15 at 18:30
  • I checked for wpa_supplicant before issuing sudo service networking stop, I guess after signal 15 it's pretty much gone and from link that you provided, I found issuing sudo wpa_supplicant -i wlan0 -c /etc/wpa_supplicant/wpa_supplicant.conf would get wpa_supplicant back) – alexus Apr 06 '15 at 18:36
I had the same problem. In my case it turned out that the input power to the Raspberry was too low. Source transformer had an output of 700mA (and 5.5v of course, since it is USB). I had connected via usb a TP Link device for the wifi connection and USB mouse and keyboard via a hub on the other USB port. That was (I guess) above the 700mA. I replace the transformer with a different one that have 1A output and I can use at the same time the usb hub and the TP link access point without the annoying signal 15 popping up. I hope it helps
