12
When NOOBS is booted up, there is a choice of a variety of Operating Systems.
Is it possible for me to add another Operating System onto this list (for example MinePeon)? If so, how do I do it?
Additional Notes: I am using a Raspberry Pi B with NOOBS 1.4.
Geek Guy
  • 151
    Is it really necessary? Can't you distribute it simply as an Image since it would obviously be easier for everyone (even noobs ;-) ) to simply write an image based distribution to an SD card using Win 32 Disk Imager or something similar – Pavin Joseph Apr 04 '15 at 12:01
  • Convert RetroPie SD Card Image to NOOBS Image https://retropie.org.uk/docs/Convert-RetroPie-SD-Card-Image-to-NOOBS-Image/ – Tapojyoti Acharya Aug 27 '16 at 14:49
Yes it is possible (since NOOBS 1.3). To do so, plug in a physical keyboard and hold shift during boot. You should see the NOOBS GUI and should be able to select an OS to install (ie Raspbian). Let this OS install, once finished and it boots to Raspbian, set it up, then reboot. Hold shift again, select the secondary OS and click install. It should ask you if you want to overwrite or just install alongside. If this sounds too complicated or doesn't work, use BerryBoot.
uSlackr
  • 185
Ben
  • 56
    I'm sorry I didn't make this clearer (now edited), I was meaning a separate Operating System that wasn't included in NOOBS. (An example being MinePeon). Thanks though :) – Geek Guy Apr 04 '15 at 15:04
  • Oh right, im not sure in noobs but ik it can be done in berryboot – Ben Apr 04 '15 at 15:06
  • using Noobs 1.4 it only gives me the option to overwrite - not install alongside – M.M May 31 '16 at 01:22
Yes, you can add operating systems in Noobs. Check out this link for further info, https://github.com/raspberrypi/noobs#how-to-create-a-custom-os-version
Shaon
    Thank you for your answer. Generally, link only answers are discouraged here, since they're subject to link rot. Please expand your answer to include at least a high level summary of its content. http://raspberrypi.stackexchange.com/help/how-to-answer – Jacobm001 Aug 10 '15 at 16:33
