Is there a web-browser for Raspbian that works with the GUI at https://github.com/? One should be able to create a repository with a license and create and edit files using the web GUI. I've tested most well known browsers already and they don't work for these tasks.
Asked
Active
Viewed 1,102 times
Iceweasel won't work for that? Really? – goldilocks Mar 21 '15 at 12:12
I didn't test Iceweasel at first because Iceape doesn't work and they should be based on the same browser-code. Iceweasel works with GitHub but takes more RAM and I experienced once that it keeps running at full speed in the background after you shut it down. A more stable and less RAM-hungry alternative to Iceweasel, that works with GitHub, would be good. – mobluse Mar 22 '15 at 08:32
Iceweasel should be pretty much firefox with a different sticker, version for version. Iceape is a more obscure cousin. I think the version of Iceweasel in Jessie is slightly newer, I don't know if that will help with the unstable thing. It probably won't with the memory thing.... – goldilocks Mar 22 '15 at 11:52
...512 MB is pretty tight for a GUI system + modern browser, all of which are hefty. Most phones have a lot more than that now. – goldilocks Mar 22 '15 at 11:53
What about Chromium?
To install type the following in the console:
sudo apt-get install chromium
You could also try Iceweasel. (Haven't tested it yet but should probably work)
Jacques Marais
- 121
- 3
No, the current version of Chromium for Raspbian Wheezy doesn't work for GitHub on Raspberry Pi 1 B+, but Iceweasel does. I didn't test Iceweasel at first because Iceape doesn't work and they should be based on the same browser-code. Iceweasel works with GitHub but takes more RAM and I experienced once that it keeps running at full speed in the background after you shut it down. A more stable and less RAM-hungry alternative to Iceweasel would be good. – mobluse Mar 22 '15 at 08:30
