12
I just bought a new Model A+ board, and noticed that the GPIO pins 13 and 14 (board pins 21 and 23) are soldered together on the backside. This was not the case with my previous A+ board: see the two compared side-by-side below.
  1. Is this an error in the board, or the intended configuration?
  2. If this is an error, should I remove the solder before using the board (even if I don't intend to use these pins)?
New vs old board
Ted Pudlik
  • 243
No they should not be soldered together (this is called a solder bridge). You should initiate a return request. You could cut or rework the trace yourself, but I would still suggest returning it - if you have problems down the road you may not be able to successfully return it if you cut the bridge yourself..
Steve Robillard
  • 34,687
  • 103
  • 109
    If you have a good iron, I'd ask support if I can attempt to rework it as that error could literally be solved in seconds with 3 cents-worth of braid rather than the huge hassle and cost of RMA'ing the thing. – Nick T Mar 15 '15 at 17:05
    My iron doesn't get hot enough to do the job, so I got in touch with Newark about replacing the Pi. Thank you both for quick replies! – Ted Pudlik Mar 15 '15 at 18:41
They shouldn't be soldered together, try returning it and DO NOT use it during the time as something could happen.
Robin
  • 171
PyxlWuff
  • 283
