Hi I bought this Comfast Wifi Adapter WU810n and came to know that it's not supported by raspbian directly. So I did follow http://www.raspberrypi.org/forums/viewtopic.php?f=28&t=62371 and get it working. But yesterday I flashed my sd-card with the lastest raspbian version and now when I run lsusb it doesn't show Realtek.
pi@raspberrypi ~ $ lsusb
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp.
When I run dmesg this is the output I get :
[139.747787] usb 1-1.2: new high-speed USB device number 4 using dwc_otg
[ 139.849099] usb 1-1.2: New USB device found, idVendor=0bda, idProduct=8179
[ 139.849142] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 139.849161] usb 1-1.2: Product: 802.11n NIC
[ 139.849178] usb 1-1.2: Manufacturer: Realtek
[ 139.849194] usb 1-1.2: SerialNumber: 00F1408816F7
[ 139.929687] r8188eu: module is from the staging directory, the quality is unknown, you have been warned.
[ 139.948403] Chip Version Info: CHIP_8188E_Normal_Chip_TSMC_UNKNOWN_CUT(10)_1T1R_RomVer(0)
[ 139.992479] usbcore: registered new interface driver r8188eu
[ 140.213122] r8188eu 1-1.2:1.0: Direct firmware load for rtlwifi/rtl8188eufw.bin failed with error -2
[ 140.213169] r8188eu 1-1.2:1.0: Firmware rtlwifi/rtl8188eufw.bin not available
[ 140.213192] MAC Address = 00:f1:40:88:16:f7
[ 140.285819] usb 1-1.2: USB disconnect, device number 4
[ 140.286600] R8188EU: ERROR indicate disassoc
