Those instructions target the OS, Raspbian, and not any particular pi model. So if you are using Raspbian, they should be fine.
If you have a screen and keyboard attached, you don't have to do the thing with screen
when you compile, just leave it running. That's this part:
./configure --with-tlslib=OpenSSL && make && sudo make install && sudo make install-conf
Instead, do those one at a time and add -j4
to the make
make -j4
sudo make install
The -j4
may speed things up by exploiting the four cores. If so, that step should only take 5-10 minutes on the pi 2 instead of 20 -- on the other hand, it may take almost as long if there is not enough stuff to do in parallel.
If you are using jessie, the unrar
version mentioned at the beginning can be gotten here (that's a link into this repo). Download that to the pi and:
tar -xzf unrar-nonfree_5.0.10.orig.tar.gz
cd unrar
make -j4
sudo make install
You'll probably need sudo apt-get install build-essential libsigc++-dev
first.
