16
I exactly followed these instructions on the official RPi site to install TightVNC on my Pi (model 2). The Pi has a static IP address and I can ping it and SSH in (obviously), so I know it's working.
When I try to connect using the Windows TightVNC client, however, I get a message that the server actively refused the connection. I'm using 192.168.x.x:0 to connect, but I also tried 192.168.x.x:5900 as recommended elsewhere, neither worked. What do I need to do to get TightVNC to properly work?
ps aux | grep vnc returns the following:
root      1888  0.0  0.0   1768   376 ?        S    11:26   0:00 /bin/sh /etc/init.d/vncboot start
root      1899  0.0  0.3   4756  3752 ?        S    11:26   0:00 /usr/bin/perl /usr/bin/vncserver :0 -geometry 1920x1080 -depth 32 -pixelformat rgb565
root      2055  0.0  0.0   1692   272 ?        S    11:26   0:00 vncpasswd /root/.vnc/passwd
netstat -l returns this:
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address           Foreign Address         State
tcp        0      0 *:ssh                   *:*                     LISTEN
udp        0      0 192.168.6.31:ntp        *:*
udp        0      0 localhost:ntp           *:*
udp        0      0 *:ntp                   *:*
Active UNIX domain sockets (only servers)
Proto RefCnt Flags       Type       State         I-Node   Path
unix  2      [ ACC ]     STREAM     LISTENING     4914     /tmp/.X11-unix/X0
unix  2      [ ACC ]     STREAM     LISTENING     4887     /var/run/dbus/system_bus_socket
unix  2      [ ACC ]     STREAM     LISTENING     4913     @/tmp/.X11-unix/X0
unix  2      [ ACC ]     STREAM     LISTENING     6965     /tmp/.pcmanfm-socket--0-pi
unix  2      [ ACC ]     STREAM     LISTENING     4972     /tmp/ssh-yoCLTWKx0wUO/agent.2194
unix  2      [ ACC ]     STREAM     LISTENING     8238     /tmp/.menu-cached-:1-steven
unix  2      [ ACC ]     SEQPACKET  LISTENING     419      /run/udev/control
unix  2      [ ACC ]     STREAM     LISTENING     5730     @/tmp/dbus-GF4T9MxwNb
unix  2      [ ACC ]     STREAM     LISTENING     5779     /tmp/.menu-cached-:0-pi
vaindil
  • 269
    I know that just sending a link to answer a question is lame, (apologies) but if the instructions at the following don't work, let me know (https://leanpub.com/RPiMRE/read#leanpub-auto-remote-access-via-tightvnc) – d3noob Feb 28 '15 at 08:32
I know this was asked a long time ago, but I found an solution to this problem.
If you start it using display :1 (or something more than 0), you have to enter the IP like this: 192.168.x.x:590<displayNumber> (like this 192.168.1.23:5901).
I hope this helps a future user
jdtech
  • 451
  • In the TightVNC viewer you have to specify the port number, i.e. 192.168.0.10::5901 (yes, double colon) –  Nov 08 '15 at 13:31
  • I find it baffling that I've gone through numerous tutorials that don't mention this fairly critical piece of information! Thank you. – Manachi Jan 13 '20 at 08:09
I think that the number 0 of Xserver is for the real screen (HDMI on the real pi).
So, do not login to the GUI desktop after booting up. Or you can try to use :1 instead.
tightvncserver :1
Below is a config file for auto startup.
#!/bin/sh
### BEGIN INIT INFO
# Provides: tightvnc
# Required-Start: $remote_fs $syslog
# Required-Stop: $remote_fs $syslog
# Default-Start: 2 3 4 5
# Default-Stop: 0 1 6
# Short-Description: Start VNC Server at boot time
# Description: Start VNC Server at boot time.
### END INIT INFO
Set the VNCUSER variable to the name of the user to start tightvncserver under
VNCUSER='pi' eval cd ~$VNCUSER case "$1" in start) su $VNCUSER -c '/usr/bin/tightvncserver :1 -geometry 1200x700 -depth 16 -pixelformat rgb565' echo "Starting TightVNC server for $VNCUSER " ;; stop) pkill Xtightvnc echo "Tightvncserver stopped" ;; *) echo "Usage: /etc/init.d/tightvnc {start|stop}" exit 1 ;; esac exit 0
Save this file to /etc/init.d/tightvnc, and add it to start-up list.
sudo chmod 755 tightvnc
sudo update-rc.d tightvnc defaults
mteam88
nightseas
  • Running OS X default VNC connection. After enabling VNC on Rpi Gui config I couldn't connect anymore... Starting TightVNC with :1 at Rpi command line fixed the issue for me. Auto start-up worked like a charm as well. Thanks!! – brasofilo Feb 14 '17 at 03:33
This does NOT work. Many people (including myself) have tried, unsuccessfully.
If fact, it probably does work, but only if you try to connect as root, which is not a good idea, and not what most people expect.
tightvncserver can not share the user desktops until the user is logged in.
I suggest you first logon using ssh and start tightvncserver. You can then connect using a VNC client.
After you install TightVNC on server(pi) and client(remote computer) you have to put a password on server end. Type vncpasswd in tight vnc server's terminal (i.e pi). Give a password and then try to login your pi.
Coderaemon
  • 465
