(Using ubuntu 14 on a laptop) I followed this guide to set up my wifi by sshing into the pi via ethernet. I checked my routers networks settings and it showed two ip addresses from the pi, and I could ssh into the wireless address without a problem.
When I unlplugged the ethernet and restarted the pi the wifi address does not show up, and I can't ssh in.
I tried restarting it with and without ethernet with the same results. whats happening?
Here is my interfaces file:
auto lo
iface lo inet loopback
iface eth0 inet dhcp
allow-hotplug wlan0
auto wlan0
iface wlan0 inet dhcp
wpa-ssid "Patty likes oldman"
wpa-psk "analrapist"
iface default inet dhcp
Here is my wpa_supplicant.conf file:
update_config=1
network={
ssid="Patty like oldman"
psk="analrapist"
# Protocol type can be: RSN (for WP2) and WPA (for WPA1)
proto=WPA
# Key management type can be: WPA-PSK or WPA-EAP (Pre-Shared or Enterprise)
key_mgmt=WPA-PSK
# Pairwise can be CCMP or TKIP (for WPA2 or WPA1)
pairwise=TKIP
#Authorization option should be OPEN for both WPA1/WPA2 (in less commonly used $
auth_alg=OPEN
tkelly003
This applies to Raspbian Wheezy prior to 2015-05-05 for later (and Jessie) See How do I set up networking/WiFi/Static IP
This SHOULD work, but without seeing your /etc/network/interfaces it is hard to know.
I do not think this is the best option. I suggest /etc/network/interfaces should contain
allow-hotplug wlan0
auto wlan0
iface wlan0 inet manual
wpa-roam will keep trying to reconnect when it finds no wired network.
wpa-conf option will not keep reconnecting.
It is difficult to find the documentation for these commands.
    so I shouldn't put the password ssid and psk in the interfaces file? will it just get them from wpa_supplicant.conf? – tkelly003 Feb 27 '15 at 04:04
  • There are many ways to do this. Anyone can read /etc/network/interfaces so this is a security risk. In addition you can put many different networks in wpa_supplicant.conf – Milliways Feb 27 '15 at 04:17
  • this doesn't seem to be working, I've added the related files to my question – tkelly003 Feb 27 '15 at 04:30
  • You didn't setup as above. I particular iface wlan0 inet manual. Frankly most people who try to set these up manually get it wrong. The easiest and most reliable way to set up initially is with a monitor attached to the Pi, using the GUI setup utility. After this you can use ssh. – Milliways Feb 27 '15 at 05:04
  • It still doesnt work with this change. Unfortunately I don't have a monitor to use with it. I can use a remote desktop with ethernet though, where do I find the set up itility? – tkelly003 Feb 27 '15 at 05:16
