So I need NetworkManager 1.0 on my Rpi to be able to setup new wifi connections via nmcli.
There is a package in experimental debian repo: https://packages.debian.org/network-manager
I made
$ sudo echo "deb http://ftp.debian.org/debian experimental main" >> /etc/apt/sources.list
Then
$ sudo apt-get update
$ sudo apt-get upgrade
$ sudo apt-get -t experimental -f install network-manager
And got
Reading package lists... Done
Building dependency tree
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
 network-manager : Depends: libc6 (>= 2.17) but 2.13-38+rpi2+deb7u7 is to be installed
                   Depends: libgcrypt20 (>= 1.6.0) but it is not installable
                   Depends: libgnutls-deb0-28 (>= 3.3.0) but it is not going to be installed
                   Depends: libndp0 (>= 1.2) but it is not installable
                   Depends: libnl-3-200 (>= 3.2.21) but 3.2.7-4 is to be installed
                   Depends: libnl-genl-3-200 (>= 3.2.21) but 3.2.7-4 is to be installed
                   Depends: libnm0 (>= 1.0.0) but it is not going to be installed
                   Depends: libsystemd0 but it is not going to be installed
                   Depends: libteamdctl0 (>= 1.9) but it is not installable
                   Depends: libpam-systemd but it is not going to be installed
                   Recommends: ppp (>= 2.4.6) but it is not going to be installed
                   Recommends: iputils-arping but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
Ok. I considered to try to compile sources. Downloaded NetworkManager-1.0.0.tar.xz and tried to ./configure. Another story about dependencies started.
echo "APT::Default-Release \"stable\";">> /etc/apt/apt.conf.d/50raspi
echo "deb http://ftp.ru.debian.org/debian testing main contrib" >> /etc/apt/sources.list
sudo apt-get install intltool
sudo apt-get install libdbus-1-dev libdbus-glib-1-dev
sudo apt-get install libgudev-1.0-0 libgudev-1.0-dev
sudo apt-get install libnl-3-200=3.2.24-2 libnl-3-dev=3.2.24-2 libnl-route-3-200=3.2.24-2 libnl-route-3-dev=3.2.24-2 libnl-genl-3-200=3.2.24-2 libnl-genl-3-dev=3.2.24-2
sudo apt-get install uuid uuid-dev
sudo apt-get install libreadline-dev libncurses5 libncurses5-dev
sudo apt-get install libnss3 libnss3-dev
sudo apt-get install ppp-dev
sudo apt-get install libndp-tools libndp-dev
And in the end it asked for libndp which lead me to
sudo apt-get -f install libc6=2.19-13
And i wasn't able to install it
Preparing to replace libc6:armhf 2.13-38+rpi2+deb7u7 (using .../libc6_2.19-13_armhf.deb) ...
Checking for services that may need to be restarted...
Checking init scripts...
/var/lib/dpkg/tmp.ci/preinst: 191: /var/lib/dpkg/tmp.ci/preinst: runlevel: not found
Unpacking replacement libc6:armhf ...
dpkg: warning: subprocess old post-removal script was killed by signal (Segmentation fault)
dpkg: trying script from the new package instead ...
dpkg: error processing /var/cache/apt/archives/libc6_2.19-13_armhf.deb (--unpack):
 subprocess new post-removal script was killed by signal (Segmentation fault)
dpkg: error while cleaning up:
 subprocess installed pre-installation script was killed by signal (Segmentation fault)
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
Any suggestions would be highly appreciated.
Finally i was able to build NetworkManager 1.0 from sources for clean raspbian "jessie".
Thanks @goldilocks for his suggestion about jessie, it saved few days for me:)
#leave only jessie in repos list
echo "deb http://archive.raspbian.org/raspbian/ jessie main contrib non-free rpi" > /etc/apt/sources.list
#Update packege repositories
sudo apt-get update
#Install packages for NetworkManager 1.0
sudo apt-get install -y intltool
sudo apt-get install -y libdbus-1-3 libdbus-1-dev libdbus-glib-1-2 libdbus-glib-1-dev
sudo apt-get install -y libgudev-1.0-0 libgudev-1.0-dev
sudo apt-get install -y libnl-3-200 libnl-3-dev libnl-route-3-200 libnl-route-3-dev libnl-genl-3-200 libnl-genl-3-dev
sudo apt-get install -y uuid uuid-dev
sudo apt-get install -y libreadline5 libreadline-dev libncurses5 libncurses5-dev
sudo apt-get install -y libnss3 libnss3-dev
sudo apt-get install -y ppp ppp-dev
sudo apt-get install -y libndp-tools libndp0 libndp-dev
sudo apt-get install -y dbus libdbus-glib-1-2 libdbus-glib-1-dev
sudo apt-get install -y gcc
sudo apt-get install -y python-gi python-dbus
#Build NetworkManager 1.0 from sources
wget http://ftp.gnome.org/pub/GNOME/sources/NetworkManager/1.0/NetworkManager-1.0.0.tar.xz
tar -xJf NetworkManager-1.0.0.tar.xz
cd NetworkManager-1.0.0
./configure
make
make check
sudo make install
BUT it doesn't work because of dbus restrictions. It need to be setup properly. Sources do include dbus rules, but seems they were not installed into the system. I tried to install them and all i was able to find in the sources but no result. It do affected on the NetworkManager, but i was not able to get it working properly in the end.
