My Raspbian Pi crashes to a Kernel panic when I start it up, and it suggested somewhere that an invalid cmdline.txt can cause this. What is in the cmdline.txt by default?
Asked
Active
Viewed 4.9k times
15
My (unaltered) PI2B has a /boot/cmdline.txt of
dwc_otg.lpm_enable=0 console=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline rootwait
There should only be one uncommented line. It is not like /boot/config.txt where you have entries on multiple lines. Line starting with # are ignored so if you want to change the line I suggest you leave the original with a # at the start.
joan
- 71,024
- 5
- 73
- 106
