Why is it that on a totally idle R-Pi B, that normally sits around 0-1% CPU utilization, if I open a LXTerminal window, it pegs the CPU at 100% even if I don't do anything but let it sit there at the $ prompt. It stays that way until I close the window, and then it drops back to 0-1%.
Asked
Active
Viewed 251 times
-1
-2
It is quite possible that the termianl software is simply running a 'loop' contineously checking for keyboard input at maximium speed (rather then checking, say 10x a second and 'sleeping' in between)...
If you are running on batteries this could be quite an issue - if that's the case all I can suggest is 'try a different terminal program' (eg BASH shell) & see if it's different
Piman
- 44
"It is quite possible that the terminal software is simply running a 'loop' contineously checking for keyboard input" -> No, GUI library APIs are event driven using callbacks. "'try a different terminal program' (eg BASH shell)" -> Bash is not a terminal emulator, it's a shell (and a terminal emulator is not a shell). Unless the system has been changed from default,
bashis running inside the terminal emulator. – goldilocks Feb 14 '15 at 16:23
toporhtopto see which process(es) are responsible? – goldilocks Feb 12 '15 at 18:25top(I think the package is calledprocps, soapt-get install procps); by default it will start with the highest CPU process at the top. It should be pretty easy to figure out. Once you know that, there may be some things you can do to further diagnose the problem -- leave a comment @goldilocks. – goldilocks Feb 13 '15 at 16:56
