I want the latest version of emacs to run on my raspberry pi.The raspberry pi runs raspbian and it seems that the repository only has version 23.4.1 which I can not use for it breaks the packages I use in emacs.So has anyone installed emacs24.4 on the raspberry pi successfully?
Ok, so a method you can try to install it, will be to compile it. To do this, follow the steps in terminal:
- Download it from GNU: wget http://gnu.mirrors.linux.ro/emacs/emacs-24.4.tar.gz
- Unzip:tar -xzvf emacs-24.4.tar.gz
- Navigate to the unzipped directory
- Type ./configure
- After the command from step 4 is done, type: make
- Finally type in terminal: sudo make install
Somehow, what I described previously are the steps to compile & and install a software on Linux distributions from sources. Also, note that you'll can have some missing dependencies, to install it(emacs) you'll have also to install the dependencies but that can be done with sudo apt-get install <dependency_name> or by repeating the steps for each dependency.
Hope I could help you!
    - 304
- 6
- 15
Emacs 24.4 compiles and runs perfectly on the new Raspberry pi 2, using these instructions:
sudo apt-get install texinfo libncurses5-dev
Install X related dependencies:
sudo apt-get install xorg-dev libpng12-dev libjpeg8-dev libgif-dev libtiff5 libtiff5-dev
Run configure script:
./configure --prefix /opt/emacs
Add --without-x to the end of the configure command if you don't need X support.
Run make:
make
Check emacs binary was built and works:
./src/emacs
If Emacs loaded up alright, quit it and run make install:
make install
Alternatively use jessie which has emacs 24.4.1 in the repository.
harry ~ $ cat /etc/os-release
PRETTY_NAME="Raspbian GNU/Linux jessie/sid"
NAME="Raspbian GNU/Linux"
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
harry ~ $ emacs --v
GNU Emacs 24.4.1
Copyright (C) 2014 Free Software Foundation, Inc.
GNU Emacs comes with ABSOLUTELY NO WARRANTY.
You may redistribute copies of Emacs
under the terms of the GNU General Public License.
For more information about these matters, see the file named COPYING.
harry ~ $
    - 71,024
- 5
- 73
- 106
                    See: http://raspberrypi.stackexchange.com/questions/26041/how-can-i-access-raspbian-jessie-packages-from-wheezy WRT installing jessie packages on raspbian wheezy. – goldilocks Jan 17 '15 at 14:19
If you are only going to use emacs in the terminal, you may spare the trouble of installing GUI-related developmental packages by doing
cd emacs-24.4
./configure --without-x
make
sudo make install
    - 1,001
- 2
- 9
- 12
Yes. I was able to install successfully:
pi@raspberrypi:~ $ emacs --version
GNU Emacs 24.4.1
pi@raspberrypi:~ $
Here are the steps:
1) upgrade the apt-get:
sudo apt-get update
2) install emacs:
sudo apt-get install emacs
    - 111
- 3
                    Is this using Raspbian Jessie, Stretch or Wheezy? If Jessie (or above), this seems pretty similar to joan's answer in terms of who it applies to. – Aurora0001 Sep 15 '17 at 19:03
                    This worked fine for me also on Raspbian GNU/Linux 9 - sudo apt-get install emacs, thank you! – Richard Logwood Mar 25 '19 at 21:04
./configure? If so it should be mentioned to make this a complete advice. – Ghanima May 03 '15 at 16:59I was able to build and install 25.3 using your instructions but installing the various dependencies separately. It was also amusing to install something like libtiff... to see libjpeg's installation remove it, or something like that.
At the conclusion, I see installed: libtiff5 libtiff5-dev libtiffxx5 libjpeg-dev libjepg8 (but not libjpeg8-dev)
emacs 25.3 is now installed on raspbian stretch, but not tested well
– Jerry Asher Sep 24 '17 at 01:50
