I am trying to start the Midori web browser on Raspberry Pi, on boot. These are the steps I've followed so far:
  1. I have edited the .bashrc file from the root folder using this command:
    sudo nano /home/pi/.bashrc
  2. Added the following line at the end of the file.
    midori -e Fullscreen -a http://www.google.com
  3. I restarted Raspberry Pi:
    sudo reboot
It does not open the browser, on boot. However, if I manually click on Terminal, it opens the browser.
I have added the below lines in the autostartup file.
# Auto run the browser
@xset s off
@xset -dpms
@xset s noblank
@midori -e Fullscreen -a http://google.
But it did not open the browser with this code when I restarted the Raspberry Pi.
Peter Mortensen
  • 2,004
Fayaz
  • 111
    As you are booting into the GUI bash is not started so .bashrc is not used. When you open a terminal a new bash shell is started and .bashrc is run. What OS are you using? – rob Jan 13 '15 at 13:31
  • Do you want it to go straight to the browser without anyone logging in, or do you want the browser to start when a user logs in? – goldilocks Jan 13 '15 at 13:43
  • I want it to directly go the browser with out log in. – Fayaz Jan 13 '15 at 13:55
  • I am using Raspbian Debian Wheezy Kernel version:3.12 . And also I have updated Raspberry pi by using the command. sudo apt-get update – Fayaz Jan 13 '15 at 13:57
  • What you want is called a kiosk. That's possible, but a little complicated to set up: http://raspberrypi.stackexchange.com/a/9692/5538 – goldilocks Jan 13 '15 at 14:12
I got the solution. In new versions it is not supported in this autostart file:
sudo nano /etc/xdg/lxsession/LXDE/autostart
I changed the code to the below autostart file.
sudo nano /etc/xdg/lxsession/LXDE-pi/autostart
Peter Mortensen
  • 2,004
Fayaz
  • 111
There is a nice autostart guide that explains how to setup the
file to autostart Midori when the Pi boots into X.
Let us know how you get on.
rob
  • 2,803
move to directory
cd /home/pi/.config/autostart/
create new file midori.desktop
sudo nano midori.desktop
and add this lines
[Desktop Entry]
Encoding=UTF-8
Name=midori
Comment=Browse the World Wide Web
GenericName=Web Browser
X-GNOME-FullName=midori
Exec=midori -e Fullscreen -a http://www.google.com
Type=Application
I tried all the mentioned methods and they did not work for me. It is noteworthy that epiphany outperforms midori in many aspects. To use epiphany, I tried this:
nano ~/.config/lxsession/LXDE-pi/autostart
the content of this file is like this:
@lxpanel --profile LXDE-pi
@pcmanfm --desktop --profile LXDE-pi
@xscreensaver -no-splash
@sh ${HOME}/.config/lxsession/LXDE-pi/autokey.sh
So, in order to ask epiphany to open on boot just add this line to the end of this file.
epiphany --display=:0 http://google.com
To prevent Raspberry to go on screen saver mode, add the following line in /etc/lightdm/lightdm.conf under [SeatDefaults] section. xserver-command=X -s 0 -dpms
That's all.
Davood
