I really detest the few fonts the console provides by default. I would like to install the Inconsolata font and use that as the default console font.
I'm using Raspbian and would like the font to be used in the console when I boot up. Can anyone provide any help on how I would achieve this?
EDIT: as I can't find much on the Inconsolata font, I'd accept any answer on how to install different fonts for the systems console.
CS Student
  • 131
I believe Inconsolata is intended as a font for a terminal in a desktop environment, not on the console. You MIGHT be able to use a utility to convert Inconsolata to the console terminal font format, in which case the converted file would get copied to /usr/share/consolefonts -- see Use or convert .ttf font for console use in FreeBSD for some ideas.
As Bex suggested, when you run
    sudo dpkg-reconfigure console-setup
you will come to a screen where you can choose from among the different fonts that are already installed.
You didn't mention what about the default fonts you "detest" -- maybe they look bad because of your monitor. They DO appear quite different, and some are better if you are using a composite monitor vs. HDMI, for example, so you might experiment to see if a different one works better. You might also adjust the brightness and/or contrast of your monitor after changing the fonts.
Have a look here for some additional suggestions: How do I increase the terminal font size?
Tommy Trussell
  • 281
Try running the sudo dpkg-reconfigure console-setup command. That should give you a font configuration wizard.
Bex
  • 2,929
  • 34
Partial solution, which needs research on your part: you'll need to do a two-step process using otf2bdf and bdf2psf. Install both:
sudo apt-get install otf2bdf bdf2psf
Download the Inconsolata OpenType file, and then create a Glyph Bitmap Distribution Format (BDF) bitmap file:
otf2bdf [options] Inconsolata.otc …
Then convert from BDF to PSF:
bdf2psf [options] file.bdf …
Notes:
  1. Both programs have slightly confusing options, so I leave the choice of bitmap size to you.
  2. otf2bdf seems to create a proportional font from Inconsolata; you will have to use options to fix this.
  3. The files in /usr/share/consolefonts/ have a very specific naming convention (not least, they have been compressed with gzip). I don't know if it's acceptable to just dump properly-named font files in there and console-setup will find them, or if there's a control file you need to edit to say what's available.
  4. Inconsolata lacks box-drawing characters, which are typically assumed to be in console fonts, so if you run curses-based programmes, the results may be unusual.
scruss
  • 9,068
  • 35
