I´ve been trying to connect my raspberry pi to my laptop by creating an AD-HOC WiFi connection between them but it doesn´t work. Could anybody please help me out. Here is some information about the error:
pi@raspberrypi -$ iwconfig
lo no wireless extensions.
eth0 no wireless extensions.
pi@raspberrypi -$ sudo /etc/init.d/networking restart
[warn] Running /etc/init.d/networking restart is deprecated because it may not re-enable some interfaces ... (warning)
[....] Reconfiguring network interfaces...wpa_supplicant: /sbin/wpa_supplicant daemon failed to start
run-parts: /etc/network/if-pre-up.d/wpasupplicant exited with return code 1
Failed to connect to wpa_supplicant - wpa_ctrl_open: no such file or directory
wpa_supplicant: /sbin/wpa_cli daemon failed to start
run-parts: /etc/network/if-up.d/wpasupplicant exited with return code 1
done.
pi@raspberrypi -$ sudo nano /etc/wpa_supplicant/wpa_supplicant.conf
update_config=1
network= {
ssid="pissh"
psk="raspberry"
proto=WPA
key_mgmt=WPA-PSK
pairwise=TKIP
auth_alg=OPEN
pi@raspberry -$ cat /etc/networks/interfaces
auto lo
iface lo inet loopback
iface eth0 inet dhcp
allow-hotplug wlan0
iface wlan0 inet manual
auto wlan0
cat /etc/network/interfacesHow did you setup wireless – Milliways Dec 23 '14 at 09:32auto lo iface lo inet loopback iface eth0 inet dhcp
allow-hotplug wlan0 iface wlan0 inet manual wpa-roam /etc/wpa_supplicant/wpa_supplicant.conf auto wlan0
– MikelThibault Jan 03 '15 at 05:16wlan0, it probably isn't. Please show dmesg output when you insert a dongle – Osman-pasha Mar 04 '15 at 06:39
