This is probably not the first digital signage discussion but I think my requirements are a bit different.
I'm looking to set up a Raspberry Pi to connect to a network via Wifi and a TV via HDMI, on boot it needs to open a URL inside a browser in full screen. That's it. Its very simple and I know it can be done. I just don't have any Raspberry Pi experience nor do I own one yet so I don't have a clue where to start.
I've just put an order for one but I'm not sure if something like this needs to be bought as a pre built kit with a box (obviously as it will be mounted on the back of a TV.
goldilocks
  • 58,859
  • 112
  • 227
Sam
    I can't see the digital signage part of the requirement. – joan Dec 19 '14 at 10:34
  • If only the Pi would be able to render HTML5 videos without too much hickups that indeed would make a great digital signage box. We've given up trying about a year ago, without finding acceptable performance in any of the browsers available. – EDP Jan 25 '16 at 17:33
That is quite a straight forward request.
Start with updating your Pi (I am assuming Raspbian)
sudo apt-get update -y
sudo apt-get upgrade -y
sudo rpi-update
sudo shutdown -r now
Then install chromium the open source version of google's chrome
sudo apt-get install chromium
then test the full screen aspects with
chromium --kiosk
Set the default homepage to the web address you want
Setup this command to run at startup, there are lots of articles detailing this, start here
How do I load a module at boot time?
If you have any specific problems with the above it may be worth starting separate questions.
rob
  • 2,803
