I am trying to setup a direct connection between my Windows laptop and RPi so that I can take projects with me to other locations without wifi and still have control over the RPi. I have removed the NOOB OS from my SD card and loaded Raspbian Wheezy and have had it all working on a separate computer screen with a keyboard and mouse however, now need to move it over to the laptop and connect as per my requirements.
I followed this tutorial to do this: Raspberry Pi Remote Connections – Without A Network!
I followed the tutorial and got to Step 2 Option 1. As per the tutorial I added the following within my cmdline.txt
file:
dwc_otg.lpm_enable=0 console=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline rootwait ip=169.254.1.7
The only thing added was the IP address at the end. I then connected the Pi to the laptop through the ethernet cable and powered the Pi, waited a few minutes and got nothing, the loading symbol stopped and there was no additional connections available, anyone have any ideas why this may be happening and how to fix it?
man nmap
to get the proper command ideas to input. Trynmap -O ###.###.###.1-254
which will give details about the OS each connected device is using, for example. – Dbo Feb 14 '15 at 15:39
