I am new to the Raspberry Pi and even new to the Raspberry Pi camera. I have seen a lot of tutorials online for the Raspberry Pi camera but have yet to find on that lets me stream straight from the Raspberry Pi camera like you can with a webcam (using SimpleCV or OpenCV). Was hoping someone could point me in the right direction.
The solution suggested by Diego is good except that it's pretty slow and has a huge video delay since the vlc there re-streams a stream of the raspvid. Since 12/2013 there is an official v4l2 driver available: http://www.ics.com/blog/raspberry-pi-camera-module#.VJFhbyvF-b8 This renders the mentioned re-streaming obsolete. Simply load the module and use it:
sudo modprobe bcm2835-v4l2
cvlc v4l2:///dev/video0 --v4l2-width 1920 --v4l2-height 1080 --v4l2-chroma h264 --sout '#standard{access=http,mux=ts,dst=0.0.0.0:12345}'
This creates an http stream at port 12345, you can use other formats too, like the rtcp one from the Diego's answer. Read more on it here: https://web.archive.org/web/20151012014829/http://www.videolan.org:80/doc/streaming-howto/en/ch03.html
2In this answer, it's suggested to add
:demux=264to cvlc because the stream is RAW h264 and you need to set the demuxer:cvlc v4l2:///dev/video0 --v4l2-width 1920 --v4l2-height 1080 --v4l2-chroma h264 --sout '#standard{access=http,mux=ts,dst=0.0.0.0:12345}' :demux=264. That's make possible to watch the stream in VLC for Android, for example. – Jaime M. May 07 '15 at 20:01 -
8In the provided link, instead of
autoreconf -vfiyou should now use./bootstrap.sh– JuJoDi Jun 01 '15 at 16:35 -
1Is there a way that will allow me to both stream the video and also save it on the RPi SD card? – Or Weinberger Dec 01 '15 at 13:03
4The http://www.videolan.org/doc/streaming-howto/en/ch03.html link is dead. – Kal Jul 02 '16 at 01:55
Here is the latest snapshot from archive.org: https://web.archive.org/web/20151211202741/http://www.videolan.org/doc/streaming-howto/en/ch03.html
There is also https://wiki.videolan.org/Documentation:Streaming_HowTo/Command_Line_Examples/, but it's not quite as in-depth.
– Kal Jul 02 '16 at 02:11 -
Doesn't work for me on RPi 3 B :( (port is open, but no stream is being transferred, vlc do nothing, browser downloads empty file). – Łukasz Zaroda Sep 09 '16 at 07:34
This does work. However for me (using RPi B+ wheezy), it's way slower than Diego's method. This is round 3-4 secs lag whereas the latter is 2 sec. What am I doing wrong? (For others: even though it creates a http stream, I have to use VLC media stream to view it. Chrome or IE tries to download a file) – Sujay Phadke Nov 06 '16 at 08:09
6I think it might be worth noting / confirming that this method does not work in a headless environment. I am getting errors, one of which talks about X11 – Nick Jan 11 '17 at 19:52
@Nick I tried on a headless environment and it works, errors talking about x11 usually are only saying that no graphical interface will be loaded, however the lag fot me is about 2s, unusable for a drone webcam – Gabber Jun 18 '17 at 17:17
This is an official about link for installing v4l2 driver https://git.linuxtv.org/v4l-utils.git/about/ – Artur Aleksanyan Jul 25 '17 at 20:38
1This is the one that worked out of the box for me. https://randomnerdtutorials.com/video-streaming-with-raspberry-pi-camera/ – Amit Ray Oct 30 '17 at 17:44
The easiest way I have found, to get a live videofeed from an headless raspberry pi, with a raspberry pi camera.
This solution works right out of the box, without installing additional software on the PI.
On the PI:
raspivid -t 0 -l -o tcp://0.0.0.0:3333
On the Computer, one can stream with VLC:
vlc tcp/h264://192.168.66.154:3333
(assuming 192.168.66.154 is the PI's IP address)
- 611
- 6
- 2
Welcome to Raspberry Pi! We generally discourage copying your answers verbatim from one question to another—once you reach 15 rep, you will be able to flag questions that are identical as 'duplicate' so that there's only one copy your answer. Thanks for sharing your answer to the problem, though! – Aurora0001 Aug 25 '17 at 10:18
@Per Hansen Not working for me...There might be something else that needs to be done apart from assigning a port. – Amit Ray Oct 30 '17 at 17:39
2This works great ! Using a RPi3B+ and Raspbian 9.4 (stretch) headless. – dparkar Jul 13 '18 at 05:51
There are several options you can choose between. At my work we are using VLC to stream video captured by Raspberry Pi Camera from our server-rooms to the office. One downside of this is that there are about 5 seconds delay and I haven't found a solution to this. The following is our setup:
Have raspbian installed and updated and make sure your camera is enabled (you enable this by running sudo raspi-config and choose Enable Camera)
sudo apt-get update sudo apt-get upgradeInstall vlc
sudo apt-get install vlcCreate a script to start the stream with the following content, or run the command (you can't do anything else if you just run the command).
sudo nano myscript.sh raspivid -o - -t 0 -hf -w 640 -h 360 -fps 25 | cvlc -vvv stream:///dev/stdin --sout '#rtp{sdp=rtsp://:8554}' :demux=h264Make the script runable
sudo chmod +x myscript.shIf you want to start the stream automatically you have to add the script to crontab. To make this work I had to make another script runned by cron (OBS! VLC can't be run as sudo so make sure you're in the right cron).
sudo nano myscript2.sh:#!/bin/bash /path/to/myscript.shThen:
sudo chmod +x myscript2.sh crontab -e @reboot /path/to/myscript2.shTo watch the videostream, open VLC on a computer on the same network as the raspberry pi you are using for streaming. Press Media -> Open Networkstream and paste the following in the field:
rtsp://[IP].[TO].[THE].[PI]:8554/
If you don't care about FPS (frames per second) and don't want any delay you could use MJPEG. You can read more about this HERE
Watch THIS wiki about Raspberry Pi Camera Module. Hope you find what you're looking for.
- 58,859
- 17
- 112
- 227
- 1,259
- 10
- 14
Any idea why I would be getting the following on VLC on Windows ? Your input can't be opened: VLC is unable to open the MRL 'rtsp://192.168.1.78:8554'. Check the log for details. The Pi-side seems to be ok - no errors and seems to reacting to the connected client? – monojohnny Mar 07 '15 at 22:54
@monojohnny Is the raspberry pi streaming? Check if the video is actually working by plugging in a screen. If video is working you should see the stream on the screen plugged to the raspberry pi. – Diego Apr 23 '15 at 12:25
@monojohnny Thanks for the write-up Diego... works perfectly on the first try! monojohnny ... you have to put the trailing "/" otherwise vlc complains. Try this: rtsp://192.168.1.78:8554/ – Sujay Phadke Nov 05 '16 at 06:04
I have the same problem on windows and i am not able to stream the video from my pi. given i see the video streaming from pi camera on a screen connected to the pi but not through VLC installed on my windows 10 pc. – Mostafa May 30 '17 at 23:01
Just does not work. Rpi3B+ VLC on the client side says "VLC is unable to open the MRL 'rtsp://192.168.137.21:12345'. Check the log for details.". Port is connectable, RPI shows no errors. – Cray Dec 09 '18 at 21:30
I tried some options. However, I found the best result using that project: RPi-Cam-Web-Interface from eLinux community
the stream has almost zero delay.
good luck :)
- 449
- 4
- 4
6People looking for zero latency, check this for sure. Props to @user2998302. I can't believe, for one year this no upvotes(acknowledgment) on this. – igauravsehrawat Nov 07 '16 at 16:57
While this is a quick and easy setup, the software is far from optimized, so while its low latency (no such thing as zero latency), the interface is very chatty, and uses some extra CPU cycles. Not a problem if you aren't running anything else, but could be if you are, especially on a Pi 1. – Nick Jan 11 '17 at 20:46
1Fastest web video streaming so far among the ones i've tested (also native v4l2 driver streamed via vlc), almost zero latency. No point in complaining about optimization while every resource on the internet regarding this problem won't get you any better result than this application does. – Gabber Jun 18 '17 at 19:10
This is the easiest one to configure, and has amazing performance. Thanks. – dsapalo Oct 21 '18 at 15:04
I faced the same problems I had in 2018 with Stretch. Used to focus a camera then stopped to take a photo, started again and it keept as stopped (in web interface). Then I tried to .remove.sh "hard". No way IP:80 still displaying an old fixed image. Running again and used Basic and Medium remove option. No way to reboot and "sudo: /usr/bin/sudo must be owned by uid 0 and have the setuid bit set" It ruined my system. – dstonek Jul 21 '20 at 00:30
This option worked very well for my pi-camera plugged into my telescope for some astrophotography. Viewing on my phone with minimal delay. – MethodMan Aug 10 '20 at 15:08
I posted a possible solution in raspberry forum using a lightweight RTSP server based on live555 that is fed with a V4L2 driver supporting H264 capture :
sudo modprobe -v bcm2835-v4l2
git clone https://github.com/mpromonet/v4l2rtspserver.git
cd v4l2rtspserver
cmake .
make install
v4l2rtspserver -H <height> -W <width> -F <fps>
Next you should be able to access to the RTSP stream using :
vlc rtsp://<raspberry>:8554/unicast
- 1,124
- 18
- 37
cmake complained about "Could NOT find ALSA (missing: ALSA_LIBRARY ALSA_INCLUDE_DIR)", until I added a few more packages for my project. Solution is within these: "sudo apt-get install libopus-dev libexpat1-dev libasound2-dev libudev-dev libavahi-client-dev" (my guess is asound may be enough here). – MoonCactus Sep 15 '16 at 07:06
1oh, and it works pretty well (lightweight solution), thanks. Time lag is decent, about 2 seconds si it compares favorably with other solutions imho. – MoonCactus Sep 15 '16 at 07:14
I agree with @MoonCactus with an RPi2B I was able to stream a 1920x1080@30 image with about 2 seconds lag, I noted that my (wired-LAN) network traffic got up to about 20Mbps but that shouldn't be a problem on most home Networks I guess. – SlySven Apr 03 '20 at 13:59
UV4L (also) supports standard HTML5 video and audio streaming with no configuration required. Other options are possible too, like MJPEG over http.
Update:
UV4L now also supports live audio & video broadcasting to Jitsi Meet Rooms over the Web. No special configuration is required. It's as easy as filling your name, room and clicking on Start.
2nd Update:
UV4L now supports H264 hardware-encoded video too, at full fps, HD and possibly Full HD in the future.
- 276
- 3
- 4
1Only thing is, you're only able to get the elemental stream which pretty much everything DOESN'T understand.
Not much use, sadly. You need something to emit WebRTC (Which if you've got a Pi2 and later, you can with UV4L. If you're needing (because of power/size constraint) a Zero to do this, your SOL.
– Svartalf Oct 29 '16 at 13:02
Both mjpeg_streamer and motion seem to have better latency than cvlc.
Using mjpg_streamer
mjpeg_streamer requires compilation but the instructions on the github are straightforward.
After compilation it can be run by launching start.sh from the project dir, or by running directly (in the project dir):
# stream with default options (port=8080) (works for USB cameras too)
./mjpg_streamer -i "./input_uvc.so" -o "./output_http.so"
# set resolution to 1920x1080 and 180° rotation
./mjpg_streamer -i "./input_uvc.so -rot 180 -r 1920x1080" -o "./output_http.so -w ./www -p 8090"
where 8090 is the TCP port. If not specified, then port 8080 will be used by default. The start.sh script contains some usage examples with extra options.
If the input_uvc.so driver is not working for you or you don't want to configure the raspberry pi camera as a UVC device, then you can also try the input_raspi.so driver.
Custom config options supported by each driver:
Using motion
Motion includes a systemd service which makes it easy to autostart at boot, stop or restart.
To use it in IP webcam mode the following settings should be set in /etc/motion/motion.conf:
daemon on
stream_localhost off # when 'on' others hosts will NOT see the server
output_pictures off
ffmpeg_output_movies off
stream_maxrate 24
framerate 24
width 640
height 480
Next, in /etc/default/motion set:
start_motion_daemon=yes
To make the service autostart on boot:
systemctl enable motion
Use systemctl start/stop/restart motion for the corresponding action.
Default streaming port is 8081. The port is set under stream_port in /etc/motion/motion.conf.
- 431
- 3
- 8
I don't know if you are looking for a surveillance software, but I have succeeded in installing and running motion, a software motion detector. You should have a look in the official guide.
- 3,703
- 3
- 22
- 38
3@geneorama motion use video4linux interface that is not restricted to USB camera, the bcm2835-v4l2 module give access to the camera board through this interface. – mpromonet Apr 13 '15 at 06:42
I was having trouble getting the video stream on windows 7. There were many linux solutions, not I couldn't replicate them on windows until now. I got a pretty quick solution eventually:
- get a windows version of netcat: http://joncraton.org/files/nc111nt.zip, unzip it and add to path
- get a new version of mpc-hc, which may read from stdin: https://mpc-hc.org/downloads/ install and add its path to path as well (mine is 64-bit, but 32-bit will hopefully do as well)
On raspberry pi:
raspivid -t 0 -w 1024 -h 768 -fps 20 -b 1000000 -o - | nc your.receiver.ip.address 5001
On windows machine:
nc -l -p 5001 | mpc-hc64 -
Thus, i deem, nothing gets repacked or restreamed, remuxed or what so ever. Binary stream from raspvid is feeded into mpc and shown. My raspberry operates over wifi, so at first I get a fair delay, which is in a matter of half a minute reduced to those 0.2-0.3 seconds delay.
Unfortunately, I couldn't use vlc in the same manner, as nc -l -p 5001 | vlc - just opens vlc window without any video.
- 1,124
- 18
- 37
- 111
I've been able to stream video using uv4l WebRTC on Raspberry Pi 2. It's super easy. Just follow this tutorial. I hope this help.
- 11
Please include relevant parts of the tutorial here, as to prevent link rot. – Bex Jul 12 '15 at 19:09
Only applicable on the Pi2 and above. Doesn't work with a 1A/1A+/Zero. Not wholly sure why he can't since people seem to be able to do it, but hey... – Svartalf Oct 29 '16 at 13:00
I have installed an ONVIF solution from https://github.com/BreeeZe/rpos on my pi, following the instructions on README.md.
The only difference is that I have installed node v8.4.0. This allows me to see my camera output in a NVR connected on same network. Also, camera can be directly played through VLC player network stream using address rtsp://192.168.1.3:8554/h264
Try my lightweight python solution. It uses the camera's V4L2 h264 stream, adds some (f)mp4 header and streams it over http.
- 151
- 5
While this link may answer the question, it is better to include the essential parts of the answer here and provide the link for reference. Link-only answers can become invalid if the linked page changes. - From Review – Chenmunka Oct 09 '21 at 09:27
While Peter Hansen's code quite possibly works fine on a LAN, for completeness sake : TCP is about data integrity as against real-time. In a real-time stream some data loss may be acceptable for the sake of timely display. In this case UDP may be better. I haven't tested that code.
If it is a security camera, multicasting may be considered. Modern routers can do it even the $100 models.
A while a go had a similar problem came up with this:
https://www.npmjs.com/package/ws-avc-player
Its more barebone than other proposed solutions, but I think it works well if low latency over web is the priority.
Works on most browsers (even mobile at 480p) without any plugins needed on the browser.
- 101
I did not write the decoder itself, its a separate project https://github.com/mbebenita/Broadway
However is surprisingly well optimised, and as I said in the answer it can easly handle a 480p on a droid.
The reason I went with Brodway is because there is no vp8/9 hardware encoder on rpi so h264 is really the only decent option. But if you want to use native h264 decoder in browser you can forget the low latency.
– MatijaG Mar 07 '18 at 10:52 -
Only now I had some spare time. I'm having trouble getting the example to run with the
raspividcamera feed. Withffmpegon the other hand I'm just getting tenth of frames per second. I used a clean Raspbian and a Pi Zero. Do you have some hints for me? – kwasmich Apr 18 '18 at 19:45 -
Yeah with ffmpeg will be a no-go becaouse of lack of hardware acceleration. Try running the example with:
node example/index.js raspividIt should work out of the box if you have issues try running justnode example/index.jsand separately/opt/vc/bin/raspivid -pf baseline -ih -t 0 -w 640 -h 480 -hf -fps 15 -g 30 -o - | nc localhost 5000and see if you get any errors from raspivid – MatijaG May 24 '18 at 08:20
ssh raspberrypi raspivid -o - -t 0 -fps 25 -w 640 -h 360 | mpv - --speed 2 --fps 25(the "--speed 2" keeps it from lagging too much). – Metamorphic Nov 23 '18 at 21:37
