-1
I'm creating a project with raspberry pi and I need an "os" which boots in a few seconds when the power is turned on. The os has to have the following features:
  • audio driver (3.5mm)
  • c/c++ running ability with sdl library(no X server)
  • ability to mount usb (or an other way to transfer files)
  • ability to install few little packages when needed (apt)
I've tried to use buildroot but I've found it too hard for me.
lenik
  • 11,541
  • 30
  • 37
Atte
  • Do tell us a little more: what task needs to come up in this time frame? – Marco Poli Jul 11 '14 at 19:54
  • What is a few seconds? Less than of the order of 30 seconds then it can't be done. – joan Jul 11 '14 at 20:00
  • You cannot have X up or even have a login or command prompt, but depending on what he needs he can have something coming up in a high priority init task way before 30 secs. – Marco Poli Jul 11 '14 at 20:13
  • Well that's good. If the OP's "few seconds" and "way before 30 secs" overlap the job is done! – joan Jul 11 '14 at 20:33
  • You haven't bothered your self with search, haven't you? This question has been discussed more then once. http://raspberrypi.stackexchange.com/questions/14763/how-to-improve-boot-time-for-raspberry-pi/14785#14785 http://raspberrypi.stackexchange.com/questions/7101/raspberry-pi-live-boot-or-read-only-distro/19830#19830 http://raspberrypi.stackexchange.com/questions/19495/is-there-a-console-only-no-gui-included-distro-under-1-gb/19502#19502 http://raspberrypi.stackexchange.com/questions/19358/how-do-i-improve-raspberry-pi-boot-up-time/19369#19369 – avra Jul 11 '14 at 20:34
  • He asked the same question 9h ago here: http://www.raspberrypi.org/forums/viewtopic.php?f=56&t=81548 – Ronny Nilsson Jul 11 '14 at 21:08
  • Arduino boot loads in less than a second. Get that. – Piotr Kula May 12 '15 at 09:01
The official OS raspbian will do, and if you use the new version / boot manager systemd it will be even faster.
But as mentioned this question is a duplicate How to improve boot time for Raspberry Pi?
user1133275
  • 2,216
I have similar problem and found that Arch Linux (and it was a first time for me - usually use Debian) to help me with boot time.
Boštjan Jerko
  • 365
