Does accidently connecting the wrong GPIO pins damage the Raspberry Pi or is there some protection like a fuse?
Asked
Active
Viewed 1.8k times
13
There are no fuses there. But what part of the GPIO pins did you connect, in what way, wrong? – ikku Oct 13 '12 at 19:31
12
Connecting the power and ground pins simultaneously, or the correct combination of GPIO and power or ground pins can fry not only the pin but the entire PI (GPIO voltage levels are 3.3 V and are not 5 V tolerant. There is no over-voltage protection on the board) . You may want to check out this article from the elinux wiki regarding protecting the GPIO Pins
Steve Robillard
- 34,687
- 17
- 103
- 109
1Thanks for clarification! Putting a zener diode and a resistor to the GPIO pins will at least help to keep calm when experimenting ;-) – Jakob Oct 14 '12 at 20:18
