Is there a precompiled binary of the latest Node.js that runs on the Raspbian OS?
2and i tried to add a 'nodejs' tag but i dont have enough awesomeness to do this here – mkoryak Sep 14 '12 at 15:26
You tried cross-compiling? – Alex Chamberlain Sep 14 '12 at 15:29
Are you asking the same as http://raspberrypi.stackexchange.com/q/1078/86 ? – Alex Chamberlain Sep 14 '12 at 15:32
@alex: maybe its the same question. it might be OS specific, in which case its a different question – mkoryak Sep 14 '12 at 17:33
Totally, setup a Cross compiler to do it. It will save hours of compile time. – Hellonearthis Sep 14 '12 at 18:10
What operating system do you do? – Alex Chamberlain Sep 14 '12 at 18:21
@AlexChamberlain: raspbian – mkoryak Sep 15 '12 at 05:05
and on your PC? – Alex Chamberlain Sep 15 '12 at 07:49
i use windows 7 – mkoryak Sep 15 '12 at 15:32
Node.js distributes official pre-compiled binaries that works on Raspberry Pi:
cd /opt
wget https://nodejs.org/dist/v9.4.0/node-v9.4.0-linux-armv6l.tar.xz
sudo tar xzf node-v9.4.0-linux-armv6l.tar.xz
sudo rm node-v9.4.0-linux-armv6l.tar.xz
sudo ln -s /opt/node-v9.4.0-linux-armv6l /opt/nodejs
sudo ln -s /opt/nodejs/bin/node /usr/bin/node
sudo ln -s /opt/nodejs/bin/npm /usr/bin/npm
To update later, just download and extract the new tar file as above and replace the '/opt/nodejs' symlink with the new release:
sudo unlink /opt/nodejs
sudo ln -s /opt/node-vX.X.X-linux-armv6l /opt/nodejs
- 105
- 4
- 536
- 4
- 4
Please do not post duplicate answers to multiple questions. The system flags this as an attempt to game the system. – Steve Robillard Nov 07 '15 at 10:36
is his answer correct though? should I accept it? It looks better than the others here – mkoryak Nov 09 '15 at 16:18
A better approach would be cross-compiling. With that you can compile in your desktop machine and install into the RPi.
Take a look at http://www.raspberrypi.org/phpBB3/viewtopic.php?f=31&t=7493
- 21
- 2
For more recent versions of node than other answers provide, Adafruit has a repository that, as of node v0.12.0 contains pre-compiled node.js.
Essentially, add the repository in Raspbian
curl -sLS https://apt.adafruit.com/add | sudo bash
Install:
sudo apt-get install node
Complete tutorial.
Note: Haven't tried this yet, but tutorial was published on 2014-12-19 at 04.57.54 PM and updated 2015-05-04 at 04.27.57 PM so seems more recent than other answers.
- 298
- 2
- 8
I was able to compile nodejs without issues using this method:
http://notetodogself.blogspot.com/2012/09/how-to-install-nodejs-on-rasberrypi.html
- 243
- 2
- 8
1Whilst this may theoretically answer the question, it would be preferable to include the essential parts of the answer here, and provide the link for reference. – Oliver Salzburg Sep 25 '12 at 17:11
I've written a script that will install the Latest version of NodeJs. Don't wast the time to compile on a raspberry pi. This will work for all raspberry pi's despite processor types (ARM6, ARM7), The scripts handles all of that. All you need to do is run this line of code:
sudo wget -O - https://raw.githubusercontent.com/audstanley/NodeJs-Raspberry-Pi/master/Install-Node.sh | bash
node -v;
source code is here: GitHub: NodeJs-RaspberryPi
- 99
- 5
