After searching all over my house, all I could find was an LG "Travel Adapter" with an output of 5.1V == 0.7A.
Will the extra tenth of a Volt harm the Raspberry Pi?
No. You have +5% tolerance. This means that the voltage should be between 4.75V and 5.25V. 5.1V should be fine.
Moreover, you can find such adapter on a list of verified power adapters on RPIs wiki.
Keep in mind, however, that 0.7A is quite low. It is recommended to have at least 0.7A but remember that you are on a low side of this parameter. Please also note that power adapters does not always provide what they say they are and there is some tolerance to it's values (and it's usually not specified by manufacturer). So if you have any problems with your board, I suggest you to do simple voltage test as described on this wiki page. Actually, I suggest to do this even if you don't see any problems and also test the voltage given without load on the PSU before connecting it to RPi.
.1 wont hurt it but in general terms yes- stick as close to 5V as possible. The BCM chip and HDMI takes power directly from this input so going overboard will hurt it.
1A is recommended for when you are using it with loads of things plugged into it. It will fine with 0.7A but if you start to experience wierd things like resets in the middle of a encoding then you need a better power adapter.
