Can some one tell me what is Raspberry Pis analog audio output capability? I would like to know how munch power 3.5 mm jack of raspberry pi can deliver in terms of watts. This will be helpful to decide what kind of speakers I can buy to use with Raspberry Pi along with many other audio devices. I am using Raspberry Pi model B with Arch Linux loaded in it. Any help is appreciated. Thanks.
You will have to purchase an amplifier. I took an old set of computer speakers and grabbed the amplifier out of it. It runs on 12v. This is a snippet from my tutorial on a Pi Arcade:
Power Harness and Audio Amplifier
When you are ready to cram all the components of your Raspberry Pi arcade into a MAME cabinet, you have the choice of suppling power to pcb, pi and monitor separately or create a single power supply.
I decided to create a single power supply with the following components. I purchased a Wall Wart Power Supply - 12VDC 1.5AMP at a local electronics store to be my main power source. I needed 12v to power the monitor (a 7" reversible car monitor). Since the pi only needs 5v, I used an old Tom Tom GPS car charger to drop the 12v to 5v. In addition, I added a audio Amplifier (12v also), The pi's audio is very low, so adding an Amplifier is needed. I found an old computer's external speakers amplifier and used it.
Pi Arcade tutorial with Audio Amplifier
- 1,210
- 2
- 16
- 28
I had to crank up the volume to max on the Pi and on my PC speakers to barely hear anything out of the Pi's builtin audio jack.
I purchased a Syba SD-CM-UAUD USB Stereo Audio Adapter to get acceptable sound from the Pi (obviously when not using HDMI which works very well). Looking on Amazon now I now see this lower cost alternative which has a comment saying someone was successfully using this unit on their Pi.
- 3,125
- 3
- 24
- 36
Thanks for the answer, heatfanjohn. I would like to know maximum power of speakers raspberry pi can output. I could not find this in technical specifications anywhere. – MVSR Jun 06 '14 at 04:30
Wolfson Audio Card- http://www.element14.com/community/community/raspberry-pi/raspberry-pi-accessories/wolfson_pi – PhillyNJ Jun 06 '14 at 10:50
