Has anybody already connected some Grove Components to the Raspberry Pi?
How do I connect the system? And where can I find code tor program it?
hifkanotiks
  • 1,901
rdmueller
  • 277
Grove is a system of some nicely packaged sensors designed to be used with SeeedStudio's Grove shields for Arduino. Since many of them are analogue sensors, you'd need an external ADC for the Raspberry Pi. Alternatively, you could attach an Arduino and communicate through that.
scruss
  • 9,068
  • 35
  • I've got the feeling that all Grove components use the i2c bus and hence bring their own ADC - am I wrong? – rdmueller Aug 23 '12 at 12:05
  • They don't look like i2c; they have separate analogue and digital plug components. – scruss Aug 23 '12 at 12:12
  • Take 3-Axis Analog Accelerometer as an example. It is using 3 pins that are directly connected to Arduinos analog pins. – Krzysztof Adamski Aug 23 '12 at 12:26
  • ok - I see: there are some I2C components (eample http://www.seeedstudio.com/wiki/Grove_-_I2C_3-axis_Accelerometer) , but most of them are analog or digital... – rdmueller Aug 23 '12 at 13:02
  • There are 4 types of grove sensors - Analog, Digital, UART and I2C. There is a complete list on the Seeed Studio wiki – Mike Causer Aug 21 '14 at 00:30
  • Check the pins on each sensor socket. Analog/Digital = SIG,NC,VCC,GND. UART = TX,RX,VCC,GND. I2C = SCL,SDA,VCC,GND. The NC stands for Not Connected (those sensors only use 3 of the 4 pins on the socket) – Mike Causer Aug 21 '14 at 00:33
Might be an old post but incase anyone finds this without knowing - the grovePi came about to solve this I think: http://www.dexterindustries.com/GrovePi/
pacifist
  • 121
This github repo also shows how to connect a single Grove sensor directly to a Raspberry Pi, however their examples will only work with a limited set of their sensors (I assume only digital sensors).
https://github.com/Seeed-Studio/Grove-RaspberryPi
bovine
  • 111
What really makes it easy to connect Grove Connectors to the Raspberry Pi, is to add a Grove shield to the Raspberry Pi, like the Pi2Grover connector.
Then it becomes plug and play with all your Python drivers available.
Here is a tutorial on how to use the devices: Tutorial: Intro to Grove Connectors for Arduino/Raspberry Pi Projects.
Greenonline
  • 2,740
  • 36
Faraday
