I have installed Jenkins, using sudo apt-get install jenkins
and it did not work immediately, so i worked out to increase the size of the /run
tmpfs. Now I am still getting errors in my jenkins.log, and I cannot access the web interface.
Running from: /usr/share/jenkins/jenkins.war
14 Aug 2012 08:28:13 winstone.Logger logInternal
SEVERE: Container startup failed
java.io.IOException: Failed to start a listener: winstone.ssl.HttpsListener
at winstone.Launcher.spawnListener(Launcher.java:229)
at winstone.Launcher.<init>(Launcher.java:185)
at winstone.Launcher.main(Launcher.java:384)
at java.lang.reflect.Method.invoke(libgcj.so.13)
at Main._main(Main.java:285)
at Main.main(Main.java:98)
Caused by: java.lang.NoClassDefFoundError: winstone.ssl.HttpsListener
at java.lang.Class.initializeClass(libgcj.so.13)
at java.lang.Class.forName(libgcj.so.13)
at winstone.Launcher.spawnListener(Launcher.java:213)
...5 more
Caused by: java.lang.ClassNotFoundException: sun.security.util.DerValue not found in java.net.URLClassLoader{urls=[file:/tmp/winstone1fdfcs.jar], parent=gnu.gcj.runtime.SystemClassLoader{urls=[file:/usr/share/jenkins/jenkins.war], parent=gnu.gcj.runtime.ExtensionClassLoader{urls=[], parent=null}}}
at java.net.URLClassLoader.findClass(libgcj.so.13)
at java.lang.ClassLoader.loadClass(libgcj.so.13)
...7 more
14 Aug 2012 08:33:33 winstone.Logger logInternal
INFO: Beginning extraction from war file
14 Aug 2012 08:34:01 hudson.WebAppMain contextInitialized
SEVERE: Failed to initialize Jenkins
java.lang.ExceptionInInitializerError
at hudson.WebAppMain.installLogger(WebAppMain.java:264)
at hudson.WebAppMain.contextInitialized(WebAppMain.java:107)
at winstone.WebAppConfiguration.<init>(WebAppConfiguration.java:875)
at winstone.HostConfiguration.initWebApp(HostConfiguration.java:129)
at winstone.HostConfiguration.<init>(HostConfiguration.java:71)
at winstone.HostGroup.initHost(HostGroup.java:87)
at winstone.HostGroup.<init>(HostGroup.java:47)
at winstone.Launcher.<init>(Launcher.java:177)
Caused by: java.lang.NullPointerException
at com.thoughtworks.xstream.core.JVM.isOpenJDK(JVM.java:72)
at com.thoughtworks.xstream.core.JVM.canUseSun14ReflectionProvider(JVM.java:198)
at com.thoughtworks.xstream.core.JVM.bestReflectionProvider(JVM.java:175)
at com.thoughtworks.xstream.XStream.<init>(XStream.java:431)
at com.thoughtworks.xstream.XStream.<init>(XStream.java:385)
at com.thoughtworks.xstream.XStream.<init>(XStream.java:323)
at hudson.util.XStream2.<init>(XStream2.java:73)
at jenkins.model.Jenkins.<clinit>(Jenkins.java:3510)
14 Aug 2012 08:34:03 winstone.Logger logInternal
SEVERE: Error during context startup for webapp webapp
INFO: HTTP Listener started: port=8080
SEVERE: Error during servlet context shutdown
java.lang.NoClassDefFoundError: jenkins.model.Jenkins
at hudson.WebAppMain.contextDestroyed(WebAppMain.java:347)
at winstone.WebAppConfiguration.destroy(WebAppConfiguration.java:1149)
at winstone.HostConfiguration.destroyWebApp(HostConfiguration.java:148)
at winstone.HostConfiguration.destroy(HostConfiguration.java:156)
at winstone.HostGroup.destroy(HostGroup.java:77)
at winstone.Launcher.shutdown(Launcher.java:337)
at winstone.Launcher.<init>(Launcher.java:199)
INFO: Winstone shutdown successfully
...5 more
Caused by: java.lang.ClassNotFoundException: sun.security.util.DerValue not found in java.net.URLClassLoader{urls=[file:/tmp/winstonepwah1w.jar], parent=gnu.gcj.runtime.SystemClassLoader{urls=[file:/usr/share/jenkins/jenkins.war], parent=gnu.gcj.runtime.ExtensionClassLoader{urls=[], parent=null}}}
...7 more
Additional information
I do not have physical access to the pi for about 5 days, so I can't reinstall the OS or similar, however I do have VNC access and I can enable SSH if i need to.
I have rebooted the pi several times, and this did not fix the problem.
/etc/default/tmpfs
usingsudo nano /etc/default/tmpfs
then I changed the size under the/run
part to about 40 MiB (This may not be completely correct, but I'm pretty sure it's right.) – hifkanotiks Aug 19 '12 at 15:19
