I have a Pi that is set-up with miniDlna for playing media to my tv and a samba server for a NAS set-up. My pi is connected to an external hard-drive that is actually just a hard drive enclosure; it uses internal ide/sata hard drives and makes them into usb hard drives. When you install the hard drive there is access to all the internal electronic components.
I want to be able to turn off the hard drive when it is not being accessed. I am thinking the best way to do this is to make a small circuit/relay that is activated by the gpio pins. Then the pi would run some software/service that would detect when the media is trying to be accessed. It would then send the signal to the gpio pin/s letting the hard-drive turn on and serve the request.
I believe I can figure out the electronics side of this project! My biggest hurdle and what I need help on is understanding what to look for within the software side and OS so I can determine when the hard drive is going to be accessed. I also am concerned with how miniDlna and samba are working? How connected and aware are they of the HD?
Anyone with any ideas of what I should look into on this would be great to here from you
hdparm -yto issue a spin-down signal to the hard-disk. That way, you don't have to worry about syncing file system changes before disconnecting the drive (since you're not disconnecting it) and it will spin up automatically when it is accessed.I measured the power using a kill a watt meter.
– Lord Loh. Sep 10 '14 at 01:38
