12
I have installed Chromium on my Raspberry Pi (running Raspian) with sudo apt-get install chromium-browser and I followed the instructions from this site to attempt to get flash player running: http://linuxologist.com/01general/howto-chromium-browser-on-linux-with-flash/
ie I just downloaded libflashplayer.so, placed it in /usr/lib/ then make a symlink to it in /usr/lib/chromium/plugins/. then i open Chromium like so:
chromium --enable-plugins --enable-greasemonkey --enable-user-scripts --enable-extensions
from the command line. However, flash player is still not recognised. The version of flash player I downloaded was from softpedia in tar, which i had to untar.
Has anyone managed to get this working? If so, then what extra steps were required?
Update
Alex requested I run file, so here it is:
$ file /usr/lib/libflashplayer.so
libflashplayer.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
mulllhausen
  • 275
6 Answers6
16
ARM vs x86
Intel processors used by desktops are 32/64-bit architectures, generally known as x86 and x86_64.
ARM processors, which is used by the Raspberry Pi, also use a 32-bit architecture, but it is incompatible with x86. Therefore, x86 libraries will not run on the Raspberry Pi.
How do I know you have an x86 library?
I asked you to run
which output
Intel 80386 tells us it was compiled for x86.
Do Adobe release an ARM version of Flash?
Yes and no. There are versions available for a lot of Mobile platforms, but I believe it is being deprecated (citation needed) and I haven't seen it available for ARM Linux. (citation needed)
Alex Chamberlain
  • 15,530
  • 67
  • 113
Gnash
Gnash is a free SWF movie player. It is available as a stand-alone application or as a plugin for several popular web browsers. It supports playing media from a disk or streaming over a network connection. Some popular video sharing sites like YouTube are supported on a wide variety of devices from embedded ones to modern desktops.
Installation
Gnash should be in the distributions' repositories.
Debian
$ sudo apt-get install gnash
Arch
$ sudo pacman -Sy gnash
Configuration
It should Just Work, but I haven't tried it yet. Will do soon.
  1. Gnash User Manual
Alex Chamberlain
  • 15,530
  • 67
  • 113
I think Adobe did not release any flash plugin of ARM Linux.
http://get.adobe.com/flashplayer/otherversions/
I don't know where do you get the "libflashplayer.so", but i guess it is X86 or X64 version.
lxp121
  • 41
Possible solution,install android on a chrooted environment. That way android can play flash because of the google chrome support and the flash plugin . Still a long way until android hits the raspberry pi.
Alternatives to Flash(If your only using it for video play back)
VLC(My favourite choice)
#Arch Linux
pacman -S vlc
#Debian
apt-get install vlc
Install this plugin . Then open VLC goto Tools > Preferences (Click All) > Interfaces > Main interface > Check Web and save. Restart and your done! OR
vlc -I http
Lightroom
ArchHaskeller
  • 1,435
  • 35
  • i installed vlc the other day as its my favourite media player and i wanted to test out a few avis. i didn't know about the chrome plugin though - that's probably the best solution to watching online flash movies (if it works well) - thanks. – mulllhausen Aug 13 '12 at 03:32
OS maemo/meego(based on debain) supports flash player on nokia n900(with ARM Cortex A8) microB Browser(based on Mozilla Firefox): http://natisbad.org/N900/n900-commented-hardware-specs.html
maemo download link: http://tablets-dev.nokia.com/ next link is needed to generate IMEI for N900 to download image files: *ttp://www.nokiaport.de/tacdatabase/index.php?s=imeitools&lng= i hope this info can help the raspberry pi community
thanks for reply if there is a chance to get it run on raspberry
Guest
Are you using Google Chrome? I think that's short for Chronium. If so, I read that Google Chrome cannot run correctly on an ARM processor. Hope this helps. Try finding a different browser, use Epiphany or your pre-installed browser, or find another one using
Chris
    Hello and welcome. I think your command is missing something. Feel free to edit your answer. – Ghanima Dec 28 '15 at 16:06
    apt-get install what exactly? You're missing the package to install. – Aloha Dec 28 '15 at 17:52
  • The latest versions of Chromium (45 at time of writing) will only work on the RPi 2 Models without (I believe) any hardware acceleration, older Q&A in this SE community may refer to it working on the older Pis but that is an ancient version 22 that is not around now I think. – SlySven Dec 28 '15 at 20:03
