I use the rt2800usb driver (with a RT5370 USB dongle) and configurated my Raspberry Pi as a WiFi hotspot with hostapd. The problem is, that I get periodically timeouts (see example). This wouldn't be a problem if I wouldn't use my RPi as a remote control for a quadcopter. It seems to be independent on how I power my RPi and it happens with all Ralink wifi dongles of this type I have.
Antwort von 192.168.42.1: Bytes=32 Zeit=1ms TTL=64
Zeitüberschreitung der Anforderung.
dmesg output:
[ 2606.960813] ieee80211 phy0: rt2800usb_entry_txstatus_timeout: Warning - TX status timeout for entry 6 in queue 2
[ 2606.960897] ieee80211 phy0: rt2800usb_entry_txstatus_timeout: Warning - TX status timeout for entry 6 in queue 2
[ 2606.960925] ieee80211 phy0: rt2800usb_entry_txstatus_timeout: Warning - TX status timeout for entry 6 in queue 2
[ 2606.961001] ieee80211 phy0: rt2800usb_entry_txstatus_timeout: Warning - TX status timeout for entry 7 in queue 2
[ 2606.961052] ieee80211 phy0: rt2800usb_entry_txstatus_timeout: Warning - TX status timeout for entry 8 in queue 2
[ 2606.961093] ieee80211 phy0: rt2800usb_entry_txstatus_timeout: Warning - TX status timeout for entry 9 in queue 2
[ 2606.961133] ieee80211 phy0: rt2800usb_entry_txstatus_timeout: Warning - TX status timeout for entry 10 in queue 2
[ 2606.961174] ieee80211 phy0: rt2800usb_entry_txstatus_timeout: Warning - TX status timeout for entry 11 in queue 2
[ 2608.352291] ieee80211 phy0: rt2800usb_txdone: Warning - Got TX status for an empty queue 2, dropping
[ 2608.352524] ieee80211 phy0: rt2800usb_txdone: Warning - Got TX status for an empty queue 2, dropping
[ 2608.352766] ieee80211 phy0: rt2800usb_txdone: Warning - Got TX status for an empty queue 2, dropping
[ 2608.353014] ieee80211 phy0: rt2800usb_txdone: Warning - Got TX status for an empty queue 2, dropping
[ 2608.353262] ieee80211 phy0: rt2800usb_txdone: Warning - Got TX status for an empty queue 2, dropping
[ 2608.353511] ieee80211 phy0: rt2800usb_txdone: Warning - Got TX status for an empty queue 2, dropping
I prepared a small graphic as illustration. I implemented my own ping function (with variable timings for testing reasons) and see every ~12s a timeout (indicated in red by a small gap). I believe the normal user will not notice these timeouts, when just surfing in the internet.
