Assuming your working with linux (raspian, debian, etc...):
Your asking two different questions, First I'll answer the title question:
Force Raspberry to get internet from specific network
I'm going to lock onto your word "network" (as opposed to "interface") and answer this in a pure IP sense:
If you have multiple connections that could provide the internet, you control which will be used via the route table.
To the view the routing table I normally use netstat -rn (-r is for "show routing", -n is for "show me numbers, don't try and do DNS lookups, which might hang if my internet isn't configured right"). A really simple example would look like this:
pi@homeServer ~ $ netstat -rn
Kernel IP routing table
Destination Gateway Genmask Flags MSS Window irtt Iface
0.0.0.0 192.168.9.1 0.0.0.0 UG 0 0 0 eth0
192.168.9.0 0.0.0.0 255.255.255.0 U 0 0 0 eth0
172.20.10.0 0.0.0.0 255.255.255.240 U 0 0 0 wlan0
pi@homeServer ~ $
The line in that output that shows which way IP packets will go is the line with a dest of 0.0.0.0 and a genmask of 0.0.0.0, that is normally known as the default route (a mask of 0.0.0.0 is all wildcard, thats really the marker of a default route), and as it currently points to a specific address in the `192.168.9' range, internet traffic will go via ethernet interface.
If I want to switch my internet to the other network I would (as root) use the route command, and in this case, given that my wifi connection isn't point-to-point I must know the ip address of the router that can forward traffic out of that network (In my case that is 172.20.10.1) so I would do:
Delete the current default route
sudo route del default
Add a new default route for the other network
sudo route add default gw 172.20.10.1
FYI while route is what I use, I see the some consider it deprecated and instead recommend using the ip route command, see @Fred 's comment below for syntax. reference for deprecation
Is there a way stay connected through the dongle's interface
Its been a while since I've worked with ppp and wvdial, and without configs (or at least references to the guides you followed in setting them up) its really hard to guess which problems your running into, but as a few ideas:
- Is the connection really down or did you just lose your default route when your eth0 came up?
- Check this in both
netstat -rn and ifconfig.
- Is an interface in
netstat -rn? if so, is there a default route to it?
- In
ifconfig do you see interface for the dongle (likely ppp)? is it UP?
- I can't remember where
ppp/wvdial log, but that should be checked. That log will tell you connection state, and should let you know if the whole system has shut down for some reason
- If you see an interface, try to
ping something (... anything ...) on it, and see if the connection comes up.
- I know the
ppp/wvdial combo has some automatic connection capability (depending on configuration)
- So if the connection came up with a ping (or the connection has stayed up the whole time): it could be the (ppp) default route got lost when you brought up the ethernet.
- If this is the problem you would just need to add a default route and the whole system would come back online.
