I tried to play compressed .mkv and compressed .m2ts and it works perfectly with omxplayer. I am just curious to know if I overclock my Pi to run .m2ts straight from a Blu-ray so it will not be laggy.
Asked
Active
Viewed 1,226 times
Alex Chamberlain
- 15,530
- 14
- 67
- 113
MrPackizz
- 109
- 3
2I'm not sure I understand your question. What do you mean straight from a Bluray? – Jivings Aug 07 '12 at 23:39
5I think he means by not playing it off his SD card as ripped content but instead from his BlurayROM (most likely connected via USB)It seems reading of BlurayROM is choppy but playing from file not.. interesting.. – Piotr Kula Aug 08 '12 at 09:07
Hi MrPackizz - welcome to Stack Exchange. What have you tried? Did you copy the .m2ts from a disk on another machine onto an SD Card? – Alex Chamberlain Aug 08 '12 at 09:21
6This is impossible to answer without further information. – Jivings Aug 08 '12 at 23:05
I suppose there is a CSS-like encryption on Bluerays (as there were for DVDs). Maybe MrPackizz is referring to the difference in smoothness with and without encryption? – Avio Sep 28 '12 at 15:49
1Over clocking your pie won't change the situation. This is probably a result of the throughput not being enough, and I would start looking at what else is going on over USB. – Bex Apr 20 '14 at 08:37
-4
I do not believe this is possible without the vid licences. Correct me if I am wrong, sorry.
Noah1111
2According to Wikipedia, the encodings used by a Blu-Ray Disc are H.262/MPEG-2 Part 2, H.264/MPEG-4 AVC, and VC-1. The RPi needs a licence to decode MPEG-2 and VC-1 only. MPEG-4 is already supported. – Morgan Courbet Dec 28 '12 at 08:04
3This should be a comment on the original question, and not an answer – Werner Kvalem Vesterås Sep 11 '13 at 19:20
Try air playing it somehow to the pi. Maybe get a sling box online. – AwesomeUser Mar 09 '14 at 20:34
