17
How do I install Retropie on a Raspberry Pi that already has Raspbian installed?
At the very worst I can use BerryBoot if I need another OS.
recantha
  • 4,489
  • 26
givensnickel
  • 181
You can just run the RetroPie setup script and it will install all the dependencies for you.
Or can use berryboot to have a completely separate partition on your SD card.
Or you can just get another SD card and dedicate it to RetroPie.
Stevoisiak
  • 321
rob
  • 2,803
install rasbian first then log on the desktop using startx and then install retro pi via the desktop consol using this method http://blog.petrockblock.com/2012/07/22/retropie-setup-an-initialization-script-for-retroarch-on-the-raspberry-pi/.
cj2tech
I would suggest the RetroPie setup script. I tried berry boot but had problems accessing the necessary files to modify the config and copy over roms. It also seemed a little slow, but that might have just been me.
Although it can take a while for the setup script to completely run, I'd suggest going that route.
Bill
  • As you may wonder about the downvotes, I'd like to point out that on this Q&A site you're expected to focus on the original question, not tell your story (even if it's related or even similar). Avoid telling about your issues in an answer, avoid asking questions in an answer and stick to the "do X and you'll get Y" format, then it'll be fine. Oh, and sorry about a cold welcome you got, this site isn't like that all the time. – Dmitry Grigoryev Jan 10 '17 at 11:00
