-2
I want to run a RPi Zero W on a crude solar panel and battery or supercapacitor.
I understand the pi has an input range of 80-120A or so, and needs a minimum of just 2 volts. This makes it ideal for me.
How can I set up the Zero W to power down if the voltage gets too low, or turn on once the voltage reaches a certain threshold, and continues running, say once clouds dissipate?
Are there any guides on this? How straight forward is it? I understand electronics, but my knowledge of the RPi is limited.
Thanks
Jodes
  • 562
    Your facts are wrong. Recommeded current capacity is 1.2Amps. Voltage is 5V. https://github.com/raspberrypi/documentation/blob/develop/documentation/asciidoc/computers/raspberry-pi/power-supplies.adoc – CoderMike Mar 29 '24 at 08:22
  • @CoderMike then how come this link says it can consume as little as 80mA? https://www.jeffgeerling.com/blogs/jeff-geerling/raspberry-pi-zero-power – Jodes Mar 29 '24 at 08:34
  • First you have to design your power management circuitry (which is likely to cost many times the cost of a PiZero) including voltage detection because the Pi has none. Once you have done this ask a question about how to shutdown the Pi using your detector. – Milliways Mar 29 '24 at 08:47
  • Thanks. I'm not concerned about the power management circuit. That should be easy. I just dont know how to interface the signals with the RPi and configure it to react accordingly. How to signal it to shut down, and how to revive it. – Jodes Mar 29 '24 at 08:57
  • Your question still says 80-120A, i assume you mean mA and 2V instead of 5V - correct your question. It may well idle at 80ma but it will likely run flat out whilst it boots requiring way more than 80ma. – CoderMike Mar 29 '24 at 09:17
    You have obviously done little research. It is simple to shutdown - there are hundreds of posts. The Pi will automatically boot when power is restored. – Milliways Mar 29 '24 at 09:46
  • Miiliways, thanks!! – Jodes Mar 29 '24 at 12:25
I've done the same thing: running an RPi from a battery charged by a solar cell. Due to the fact that the only way to achieve zero power consumption is by removing power (true for all RPi), I designed a simple circuit to accomplish that. The design requires addition of a Real Time Clock (RTC), and use of two overlays in /boot/config.txt.
There's a schematic and more details in this answer, but this answer didn't include the RTC... if you're interested & can't find the other answers, let me know & I'll try to help.
Seamus
  • 21,900
  • 70
