wayfire itself doesn't come with this feature bundled, but can be easily extended through its complementary wayfire-plugins-extra package. Unfortunately, it is not available in the Bookworm repos.
I (very) recently had a similar requirement for a project and came up with a solution. You can find my full entry here. I'll pick what is relevant for your question:
Hide mouse pointer
1) Install wayfire-plugins-extra
Compiled Library:
- Download the correct library for your architecture from here (Compiled by me. Feel free to build from source)
- Decompress with
tar xf /path/to/wayfire-plugins-extra-raspbian-<your-arch>.tar.xz
- Each plugin comes with .so and .xml files. You will need to copy those to their correct paths:
sudo cp <desired-plugin>.so /usr/lib/<your-arch-linux-gnu>/wayfire/<desired-plugin>.so
sudo cp <desired-plugin>.xml /usr/share/wayfire/metadata/<desired-plugin>.xml
Build from Source:
- Follow the instructions in https://github.com/seffs/wayfire-plugins-extra/. Install all required dev packages with
sudo apt install libglibmm-2.4-dev libglm-dev libxml2-dev libpango1.0-dev libcairo2-dev wayfire-dev libwlroots-dev libwf-config-dev meson ninja-build
meson should take care of the installation. Otherwise check if the following path exists for any new extra plugin:
ls /usr/lib/<your-arch-linux-gnu>/wayfire/<new-extra-plugin>.so
ls /usr/share/wayfire/metadata/<new-extra-plugin>.xml
2) Activate your plugin(s)
I was only interested in hiding the mouse pointer. This can be accomplished with the hide_cursor plugin. The same concept applies to the rest of plugins.
Open your ~/.config/wayfire.init file and adjust the following:
[core]
plugins = \
autostart \
### We need to add the extra plugin to the list ###
hide-cursor
Launch wayfire once again. You'll notice that the mouse pointer disappeared.
