In Bookworm (and latest Bullseye) the kernel device driver for GPIO has been updated so GPIO settings are persistent and it is now possible to specify pulls.
This means libgpiod behaves similarly to sysfs (and most tools accessing registers).
There is kernel documentation and a python module gpiod but it is difficult to follow (unless you are a kernel developer) and no User Documentation.
There are a few examples e.g. https://www.tomshardware.com/how-to/control-raspberry-pi-5-gpio-with-python-3
The current libgpiod is old (v1.6.3 in Bookworm and even older in Bullseye) the v2 code is significantly different but it unclear if or when this may be included in Raspberry Pi OS.
I decided to test the gpiod module and write a wrapper which uses the same functions as my pi_gpio library.
This obviously excludes I²C, SPI or Hardware PWM but I have code implementing these using kernel drivers which will be included in a final library as will Information functions.
This code has been updated and tested on a Pi5 and allows existing code to run with minimal change, but if writing new code use gpiod or lgpio (which is faster and includes additional functionality).
#! /usr/bin/env python3
p_gpio is a Python module for the RaspberryPi
Using gpiod Python Interface
This is a wrapper which uses the same functions as pi_gpio library.
OVERVIEW
GPIO
    setup_gpio - Set gpio as an input or an output
input_gpio - Returns the GPIO level__plibrary
output_gpio - Output to a GPIO channel
input_28 - Returns value of GPIO 0-27
output_28 - Sets value of GPIO 0-27
gpio_function - The current GPIO mode
get_pullupdn - The current GPIO pull/up down
2024-04-04
import gpiod
VERSION='0.2'
chip = gpiod.find_line('ID_SDA').owner()  # find chip with ID_SDA
gpiomap = {} # This is a dictionary to avoid repeated chip.get_line(gpio) calls
GPIO
NOTE all gpio use Broadcom BCM numbers
INPUT=0
OUTPUT=1
LINE_REQ_DIR_AS_IS = 1
LINE_REQ_DIR_IN = 2
LINE_REQ_DIR_OUT = 3
LINE_REQ_EV_BOTH_EDGES = 6
LINE_REQ_EV_FALLING_EDGE = 4
LINE_REQ_EV_RISING_EDGE = 5
LINE_REQ_FLAG_ACTIVE_LOW = 4
LINE_REQ_FLAG_BIAS_DISABLE = 8
LINE_REQ_FLAG_BIAS_PULL_DOWN = 16
LINE_REQ_FLAG_BIAS_PULL_UP = 32
LINE_REQ_FLAG_OPEN_DRAIN = 1
LINE_REQ_FLAG_OPEN_SOURCE = 2
ACTIVE_HIGH = 1
ACTIVE_LOW = 2
BIAS_AS_IS = 1
BIAS_DISABLE = 2
BIAS_PULL_DOWN = 4
BIAS_PULL_UP = 3
DIRECTION_INPUT = 1
DIRECTION_OUTPUT = 2
def setup_gpio(gpio, direction, pud):
def setup_gpio(gpio, direction, pud=0):  # optional pud
  direction: 0=IN, 1=OUT
  pud: 0=None 1=Up 2=Down
  line = chip.get_line(gpio)
  gpiomap[gpio] = line
  if direction:
    line.request(consumer="p_gpio", type=gpiod.LINE_REQ_DIR_OUT)
  else:
    f = gpiod.LINE_REQ_FLAG_BIAS_DISABLE
    if pud==1:
      f = gpiod.LINE_REQ_FLAG_BIAS_PULL_UP
    if pud==2:
      f = gpiod.LINE_REQ_FLAG_BIAS_PULL_DOWN
    line.request("p_gpio", gpiod.LINE_REQ_DIR_IN, f)
    print('pud= ', pud, 'bias= ', line.bias())
def input_gpio(gpio):
  Input from a GPIO channel.
  Returns HIGH=1=True or LOW=0=False
  return gpiomap[gpio].get_value()
def output_gpio(gpio, value):
  Output to a GPIO channel.
  value - 0/1 or False/True or LOW/HIGH
  gpiomap[gpio].set_value(value)
def gpio_function(gpio):
  Returns the current GPIO direction
  Only works if gpio in use
  Returns 0,1 (IN, OUT)
  if gpio in gpiomap:
    return gpiomap[gpio].direction() - 1
  return 0
def get_pullupdn(gpio):
  Return the current GPIO pull
  Returns
  0:None/Unknown
  1:Up
  2:Down
  if gpio in gpiomap:
    return gpiomap[gpio].bias()-2
  return 0
Dummy functions
def setup():
  pass
def cleanup():
  pass
import time
def main():
  global chip
  SigOUT = 12
  SigIN = 13
  LOOPS = 20000
  setup_gpio(SigOUT, 1, 0)
setup_gpio(SigIN, 0, 0)
setup_gpio(SigIN, 0, 1)
setup_gpio(SigIN, 0, 2)
t0 = time.time()
for i in range(LOOPS):
    output_gpio(SigOUT, 1)
    output_gpio(SigOUT, 0)
t1 = time.time()
print("gpiod Python\t{:>10.0f} toggles per second".format((1.0 * LOOPS) / (t1 - t0)))
  print("{}".format(input_gpio(SigIN)))
  print('SigIN function= ', gpio_function(SigIN))
  print('SigOUT function= ', gpio_function(SigOUT))
  print('pud= ', get_pullupdn(SigIN))
  print('pud= ', get_pullupdn(4))
if name == 'main':
    main()
