I am using this raspberry Pi
Architecture: armv7l
Byte Order: Little Endian
CPU(s): 4
On-line CPU(s) list: 0-3
Thread(s) per core: 1
Core(s) per socket: 4
Socket(s): 1
Vendor ID: ARM
Model: 5
Model name: Cortex-A7
Stepping: r0p5
CPU max MHz: 900.0000
CPU min MHz: 600.0000
BogoMIPS: 38.40
Vulnerability Itlb multihit: Not affected
Vulnerability L1tf: Not affected
Vulnerability Mds: Not affected
Vulnerability Meltdown: Not affected
Vulnerability Mmio stale data: Not affected
Vulnerability Retbleed: Not affected
Vulnerability Spec store bypass: Not affected
Vulnerability Spectre v1: Mitigation; __user pointer sanitization
Vulnerability Spectre v2: Not affected
Vulnerability Srbds: Not affected
Vulnerability Tsx async abort: Not affected
Flags: half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm
I plugged in my AC1200 USB-AC53 Nano Wi-Fi adapter and ran dmesg.
The result is:
[ 4.698502] usb 1-1.2: New USB device found, idVendor=0b05, idProduct=184c, bcdDevice= 2.10
[ 4.698556] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 4.698579] usb 1-1.2: Product: 802.11ac NIC
[ 4.698597] usb 1-1.2: Manufacturer: Realtek
[ 4.698615] usb 1-1.2: SerialNumber: 123456
I installed firmware-realtek, firmware-linux, firmware-linux-free, and firmware-linux-nonfree
then when I run ifconfig I don't see my wlan
inet 192.168.1.31 netmask 255.255.255.0 broadcast 192.168.1.255
inet6 fe80::fe91:c019:3887:5f22 prefixlen 64 scopeid 0x20<link>
inet6 fd57:c6e2:9acf:479b:3970:b963:a9ca:1d4f prefixlen 64 scopeid 0x0<global>
ether b8:27:eb:5e:2b:19 txqueuelen 1000 (Ethernet)
RX packets 154 bytes 32643 (31.8 KiB)
TX packets 78 bytes 9163 (8.9 KiB)
RX packets 17 bytes 2111 (2.0 KiB)
TX packets 17 bytes 2111 (2.0 KiB)
Any suggestions to help me with making my wifi works?
Thanks Namir
ifconfig– midnight_rambler Oct 10 '23 at 23:43ifconfig(which incidentally is deprecated) won't show an unconfigured interface.ls /sys/class/net/will show what network devices you have. – Milliways Oct 11 '23 at 00:56ipand to show all interfacesip a. – MatsK Oct 11 '23 at 09:34raspberry@satellite-0:/etc/network $ ls /sys/class/net/ eth0 lo– midnight_rambler Oct 11 '23 at 13:44
