15
I am running Raspbian, and I am trying to setup a "kiosk mode" box. I have successfully done this with midori, but midori does not support html5. so I wanted to try the new beta "web browser" (seems to run epiphany-browser).
my current setup is like this: /etc/xdg/lxsession/LXDE/autostart:
@xset s off
@xset -dpms
@xset s noblank
@midori -e Fullscreen -a http://www.playr.biz/23612/15122
this new web browser is discussed here
but when I look at the manpage, it does not say much about CLI options.
man epiphany-browser
so, my question is: how can I start the epiphany-browser in full screen mode, and start a specific URL like I have done with midori above? (if possible at all).
update: I followed advice and I tried the following in file /etc/xdg/lxsession/LXDE/autostart
@epiphany-browser http://www.playr.biz/5dd1/1ddd5
@sleep 2s
@echo key F11 | xte
but it did not make it full screen, so I tried to run xte manually, but got an error " Unable to open display 'default'"
so, I did two things, I changed the file /etc/lightdm/lightdm.conf and I looked for this line:
xserver-command=X -s 0 dpms
then I changed it to:
xserver-command=X -s 0 dpms :0
to define the display/screen as :0 (localhost number 0)
now, if I run this
echo key F11 | xte -x:0
the screen goes full screen.
but, when I update the /etc/xdg/lxsession/LXDE/autostart like this:
@epiphany-browser http://www.playr.biz/5ddd/1dddd
@sleep 60s
@echo key F11 | xte -x:0
PS: I tried 2s, 10s, 60s and 120s, but that did not help.
So I guess the @sleep 60s might not work.
techraf
  • 4,319
Sverre
  • 315
This is not a direct answer to your problem, but it is a suggestion based on the context.
Chromium (a fork of chrome) is available for the pi, supports HTML 5, and although it is undocumented, has a --kiosk mode. I tested this on the raspbian, but I imagine it is in the Arch and Pidora repos as well:
> apt-get install chromium
A surprisingly small download, < 100 MB. Then:
> chromium --kiosk
Presto, full screen. There does not seem to be a way to get it out of full screen (F11 doesn't work), but perhaps that is the point of kiosk mode.
Initially, chromium has a residential memory footprint (i.e., actual RAM usage) of ~70 MB.
goldilocks
  • 58,859
  • 112
  • 227
  • tested this now, and the kiosk mode works as adverticed, but my html5 video still complains. – Sverre Mar 17 '14 at 03:49
  • The HTML5 video standard looks to involve the usual mess of legal infighting over what formats are supposed to be supported; AFAICT reading this the result is there aren't any that are required, lol. If it is H.264, there's a note there that it was removed from chromium (but not chrome) which is a shame since the pi has hardware acceleration for that. Firefox might (have you tried that?), although firefox doesn't seem to have a fullscreen/kiosk mode except via F11. – goldilocks Mar 17 '14 at 04:28
  • I guess FF is next on my list :) – Sverre Mar 17 '14 at 04:47
  • FF did the trick.. but also chromium was very usefull, thanks for the help. – Sverre Mar 17 '14 at 07:03
It doesn't look like there's a way to do it directly, but the xte tool can be used to simulate a key press.
epiphany-browser http://www.playr.biz/23612/15122
sleep 2s # give it time to start
echo key F11 | xte # simulate pressing the full screen key
Fred
  • 4,552
  • 29
  • Thanks, I will try this. I would vote you up, but I have no karma on this one. (raspberry pi) – Sverre Mar 14 '14 at 08:43
  • I installed xautomation to get xte, but when I try to run xte I get this error message "Unable to open display 'default' tried to google it, but so far nothing – Sverre Mar 14 '14 at 10:03
    Try "DISPLAY=:0 echo key F11 | xte" instead. – Fred Mar 15 '14 at 11:28
  • yes did that, thanks.. helped. now I only need to make the delay work :) – Sverre Mar 15 '14 at 11:35
    I think the problem may be the @. According to the ArchWiki (https://wiki.archlinux.org/index.php/LXDE#Autostart_files), that's used for processes that need to continuously be restarted if they crash, which means that whole file is executed non-linearly. That is to say the sleep doesn't actually do anything. Put it all into a bash script to ensure linear execution, and have the autostart file call that, so that if it does crash it gets restarted. – Fred Mar 15 '14 at 11:39
  • Thanks for your help, you helped me a lot, and your answer actually answered my question, even if I ended up using a different browser for now. – Sverre Mar 17 '14 at 07:04
  • if I could mark both as the correct answer I would :( and I have no carma to even upvote this solution. sorry – Sverre Mar 17 '14 at 07:04
  • anyone know how to keep epiphany from reopening the last session? Can't figure how to disable such a useful and annoying "feature" – Jonathan S. Fisher Oct 31 '14 at 18:50
Here's an example of a digital picture frame using epiphany kiosk style: http://simplyautomationized.blogspot.com/2015/04/rpicframe-html5-kiosk-style-picture.html
You will need a window manager opened before launching. matchbox-window-manager is light weight
The -a in the CLI will load it in kiosk mode:
sudo -u pi epiphany-browser -a --profile ~/.config http://localhost/index.html
raspi-ninja
  • 879
I think the trick here is to include the sleep command in the automation script instead of depending on /bin/sleep.
My /etc/xdg/lxsession/LXDE-pi/autostart looks like this and seems to work as intended:
@xset s off
@xset -dpms
@xset s noblank
@epiphany-browser index.html
@xte 'sleep 10' 'key F11'
Of course you should replace 'index.html' with a real URL and you still need the xautomation package.
Greenonline
  • 2,740
  • 36
