After researching a lot on the internet, I found that there is no easy/standard/official way to assign a static IP to a Raspberry Pi.
Why is so much tweaking needed in the config files even if I can assign a static IP using my network router?
If I assign a static IP using my Router (ethernet and WiFi each), then the Raspberry Pi won’t be able to connect to the internet. Although I can:
ping 8.8.8.8
pi@raspberrypi:~ $ ping google.com
ping: google.com: Temporary failure in name resolution
pi@raspberrypi:~ $ ping 8.8.8.8
PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
64 bytes from 8.8.8.8: icmp_seq=1 ttl=53 time=64.9 ms
64 bytes from 8.8.8.8: icmp_seq=2 ttl=53 time=115 ms
^C
--- 8.8.8.8 ping statistics ---
2 packets transmitted, 2 received, 0% packet loss, time 1001ms
rtt min/avg/max/mdev = 64.886/89.857/114.828/24.971 ms
pi@raspberrypi:~ $ ifconfig
inet 192.168.1.200 netmask 255.255.255.0 broadcast 192.168.1.255
inet6 2402:ad80:f0:3ea8:39ca:f0c2:8ff8:c6cb prefixlen 64 scopeid 0x0<global>
inet6 fe80::d65e:5364:a0db:1705 prefixlen 64 scopeid 0x20<link>
ether dc:a6:32:84:a8:e8 txqueuelen 1000 (Ethernet)
RX packets 22976 bytes 3758615 (3.5 MiB)
TX packets 28514 bytes 18563719 (17.7 MiB)
RX packets 94006 bytes 8755506 (8.3 MiB)
TX packets 94006 bytes 8755506 (8.3 MiB)
wlan0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether dc:a6:32:84:a8:e9 txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
TX packets 0 bytes 0 (0.0 B)
pi@raspberrypi:~ $ route -n
Kernel IP routing table
0.0.0.0 192.168.1.1 0.0.0.0 UG 202 0 0 eth0
192.168.1.0 0.0.0.0 255.255.255.0 U 202 0 0 eth0
pi@raspberrypi:~ $ cat /etc/networks
default 0.0.0.0
loopback 127.0.0.0
link-local 169.254.0.0
pi@raspberrypi:~ $ cat /etc/network/interfaces
source /etc/network/interfaces.d/*
pi@raspberrypi:~ $ cat /etc/network/interfaces.new
pi@raspberrypi:~ $ cat /etc/dhcpcd.conf
hostname
persistent
option rapid_commit
option interface_mtu
slaac private
# Example static IP configuration:
#interface eth0
#static ip_address=192.168.0.10/24
#static ip6_address=fd51:42f8:caae:d92e::ff/64
#static routers=192.168.0.1
#static domain_name_servers=192.168.0.1 8.8.8.8 fd51:42f8:caae:d92e::1
# It is possible to fall back to a static IP if DHCP fails:
# define static profile
#profile static_eth0
#static ip_address=192.168.1.23/24
#static routers=192.168.1.1
#static domain_name_servers=192.168.1.1
# fallback to static profile on eth0
#interface eth0
#fallback static_eth0
interface eth0
static ip_address=192.168.1.200/24
Resources:
https://windowsreport.com/raspberry-pi-no-connect-internet/
Raspberry Pi Won't Connect Through Ethernet
Why is so much tweaking needed in the config files even if I can assign a static IP using my network router?So much tweaking?? What did you have to tweak outside ofdhcpcd.conf? – Seamus Sep 28 '23 at 21:48uptime-kuma,plex,pi-hole,transmission,pm2,IoTs manager, etc. Until now the board is handling it fairly well. – Dürrani Sep 29 '23 at 13:02
