-1
What is the proper format of adding in multiple SSID's? I have the following below. Do I add a comma like in JSON format?
    # For more configuration option please see:
    # https://w1.fi/cgit/hostap/plain/wpa_supplicant/wpa_supplicant.conf
ctrl_interface=/var/run/wpa_supplicant
ctrl_interface_group=0
ap_scan=1
network={
ssid="x"
    # Uncomment to connect to Hidden SSIDs
    #scan_ssid=1
    key_mgmt=WPA-PSK
    pairwise=CCMP TKIP
    group=CCMP TKIP WEP104 WEP40
    psk="_______"
    priority=2
JoSSte
  • 147
Patoshi パトシ
  • 551
You add multiple network stanzas.
What you have listed is incorrect for the Pi (and most Linux OS) - among other things you omitted Country Code.
See https://raspberrypi.stackexchange.com/a/37921/8697
The proper format to be followed is defined in the manuals for wpa_supplicant, and wpa_supplicant.conf; e.g. man wpa_supplicant. You can also find a good explanatory document for building your own wpa_supplicant.conf file in your local filesystem at: /usr/share/doc/wpa_supplicant/examples/wpa_supplicant.conf
It's not JSON...
In the simplest case, something like this may suffice for small, personal networks:
update_config=1
network={ ssid="WiFiNetworkUpstairs" psk="WiFiPasswordForUpstairs" }
network={ ssid="DownstairsWiFiNetwork" psk="WiFiPasswordForDownstairs"
} network={ ssid="AnotherWiFiNetwork" psk="AnotherWiFiPassword" }
etc, etc, etc
Seamus
  • 21,900
  • 70
