Symptoms
ssh connection to raspberrypi hangs after rougly 30 seconds, unless I ping the raspberrypi.
The raspberry pi is at raspberrypi.lan
I have a script ~/troubleshoot.sh
#! /bin/bash
uptime
free
while :; do
sleep 1; echo $SECONDS
done
I can run this while logged into raspberrypi.lan via ssh, or run it remotely from my laptop:
ssh raspberrypi ./troubleshoot.sh
19:34:35 up 11 days, 23:05, 2 users, load average: 0.00, 0.01, 0.00
total used free shared buff/cache available
Mem: 439596 73516 112016 160 254064 308364
Swap: 102396 101940 456
... 4, 5, 6 etc ...
27
28
29
This will hang when $SECONDS is around 30 ... it might be as low as 28, or as high as 34. When run remotely, I have to use Ctrl+C to terminate.
If I'm logged into raspberrypi.lan via ssh, I see the same behavior, but I have to use Enter ~ ..
... so something is causing the ssh session to hang.
If I open a separate terminal window on my laptop and run
ping raspberrypi.lan
the ssh session will not hang; I can stay logged on indefinitely.
History
I had an old version of Raspbian running on the pi -- so old that the repositories were well out of date. ssh worked under that version. I loaded Raspbian GNU/Linux 11 (bullseye) on a new SD card and enabled ssh, then noticed that my ssh sessions were freezing after a short period of time.
Environment
Hardware: Raspberry Pi 1B
OS/Distro Version: Raspbian GNU/Linux 11 (bullseye)
Network: Wired, dual stack (ipv4, ipv6)
$ host raspberrypi.lan raspberrypi.lan has address 192.168.12.189 raspberrypi.lan has IPv6 address 2607:fb90:2c88:43b2:b04c:80cb:0:167
IP addresses are dynamic on both IPV4 and IPV6
sshd:
OpenSSH_8.4p1 Raspbian-5+deb11u1, OpenSSL 1.1.1n 15 Mar 2022/etc/ssh/ssh_config:Include /etc/ssh/ssh_config.d/.conf Host * SendEnv LANG LC_ HashKnownHosts yes GSSAPIAuthentication yesno files in
/etc/ssh/ssh_config.d//etc/ssh/ssh_configis identical to that of another server that I have no issues logging in to.~/.ssh/configon laptop:Host raspberrypi User barton Hostname raspberrypi.lan ServerAliveInterval=60 ServerAliveCountMax=10
What I've tried so far
~/troubleshoot.shshows uptime -- this is now over 12 days. This rules out power issues causing the pi to reboot.raspberrypi.lanis constantly pingable -- this isn't a network connectivity issue.- All ip addresses on the lan are dynamic; this isn't an IP address conflict.
- I used the
check.shscript posted by @goldilocks in his reply to Raspberry pi always stops responding to SSH after some hours powered to determine thatsshdis not dying. - Tried adding
ServerAliveInterval 60 ServerAliveCountMax 10to/etc/ssh/ssh_configand restarting sshd. No change. - Looked in
/var/log/syslogand/var/log/messagesfor ssh errors. Didn't see anything. - Tried connecting using
ssh -v -v -v raspeberrypi.landidn't see anything unusual (much as I suspected, since I was connecting correctly). - Ran
journalctl -u ssh-- I probably need to go a bit farther down this path, because I was tired when I tried it, and didn't think tonohupit and redirect to a file.
