Im working on doing some remote GPIO control (de)energizing relays. When I turn a relay on, it instantly turns off. That makes me assume that the output doesn't latch. I tried several of the classes used to control digital IO remotely but all of them behave the same.
from gpiozero import OutputDevice
from gpiozero.pins.pigpio import PiGPIOFactory
factory = PiGPIOFactory(host='d1p-woctorelay.local')
#RD1P Relays
las_test = OutputDevice(15, pin_factory=factory)
las = LED(5, pin_factory=factory)
rex = LED(6, pin_factory=factory)
ras = LED(13, pin_factory=factory)
las_test.on()
las.on()
rex.off()
Is there something I'm missing in the docs or some basic trick to latching remotely? I came across this SO post but it doesn't seem to work the same for remote control.
