TLDR; I want to disable the USB hub on a RPi4 until boot is complete.
Hi, I am trying to solve a problem that I have not seen posted about.
I have a RPi4 with multiple RPiZs plugged into it acting as ethernet gadgets. The RPiZs connect to different interfaces (usb1:usb4) based on udev rules
and interfaces set up in the /etc/dhcpcd.conf which match the set ups on the individual RPiZ.
When I plug a RPiZ into the RPi4 via USB, it powers up and connects via ethernet over usb. The RPi4 assigns the corresponding interface and IP address perfectly.
However, an issue occurs if the entire system is powered on at the same time. The ethernet over usb connection is made before the rules are established and the RPiZ is assigned to interface usb0 and given a random ip-address.
I have a simple script (see below) based on this question: How do I reset a USB device using a script?
The script resets USB hub which resets the network which fixes the interfaces and IP addresses. However, for automation reasons, it is important that connections are right on the first try.
I suspect the problem would be solved if I could disable the USB hub (either power or just data) until the boot is complete. I have seen a lot of threads about disabling USB after boot, but none about disabling before boot. I would appreciate any help I can get. Thanks.
# /etc/udev/rules.d/90-usbpi.rules
SUBSYSTEM=="net", ATTR{address}=="00:22:82:ff:ff:01", NAME="usb1"
SUBSYSTEM=="net", ATTR{address}=="00:22:82:ff:ff:02", NAME="usb2"
SUBSYSTEM=="net", ATTR{address}=="00:22:82:ff:ff:03", NAME="usb3"
SUBSYSTEM=="net", ATTR{address}=="00:22:82:ff:ff:04", NAME="usb4"
# added to /etc/dhcpcd.conf.
interface usb1
static ip_address=10.0.11.1/24
interface usb2
static ip_address=10.0.12.1/24
interface usb3
static ip_address=10.0.13.1/24
interface usb4
static ip_address=10.0.14.1/24
#!/bin/bash
ID=0525:a4a2
logger "Searching for $ID"
devPath=`lsusb | grep $ID | sed -r 's/Bus ([0-9]{3}) Device ([0-9]{3}).*/bus\/usb\/\1\/\2/g;'`
logger "Found $ID @ $devPath"
logger "Searching for sysPath"
for sysPath in /sys/bus/usb/devices/*; do
logger "$sysPath/uevent"
devName=`cat "$sysPath/uevent" | grep $devPath`
#logger devName=$devName
if [ ! -z $devName ]
then
break
fi
done
then
logger "Found $ID @ $sysPath, Resetting"
logger "echo 0 > $sysPath/authorized"
logger "echo 1 > $sysPath/authorized"
else
logger "Could not find $ID"
fi
the RPiZ is assigned to interface usb0but you have 4 x RPiZ, what happens to the other 3 RPiZ's? – Jaromanda X May 08 '23 at 00:43
