I have followed the guides put forth in the following forum when trying to install hamachi manually on raspberry Pi OS 64-bit on a Raspberry Pi 4 8gb:
Whenever I try to use the command hamachi it gives me an error, saying:
sudo: unable to execute /usr/bin/hamachi: No such file or directory
Whereas when I go to /usr/bin/hamachi and do ls I find that hamachi is listed. Here is a link to a copy of the full export:
https://www.icloud.com/iclouddrive/07eTn9gBYmNRlR6ArXGWGnW_A#User/bin
The color it's listed in shows that the Hamachi file listed is a symbolic link. I have tried to install and uninstall hamachi a number of different ways, so it could be that the link is now broken.
I can use the command stated in the readme file to start/stop/etc. the server, however, it also states an error/notice:
pi-dragon6000@raspberrypi:~ $ /etc/init.d/logmein-hamachi start
Starting LogMeIn Hamachi VPN tunneling engine logmein-hamachi
starting - success
/etc/init.d/logmein-hamachi: 46: /opt/logmein-hamachi/bin/hamachid: not found
When I try to do the hamachi --version command shown before but instead capitalized, I get a slightly different result:
pi-dragon6000@raspberrypi:~ $ sudo Hamachi --version
sudo: Hamachi: command not found
The same happens when I use the login argument:
pi-dragon6000@raspberrypi:~ $ sudo Hamachi login
This is a section of a terminal session where I try to install hamachi:
pi-dragon6000@raspberrypi:~/logmein-hamachi-2.1.0.203-armel $ sudo ./uninstall.sh
Stopping LogMeIn Hamachi engine ..
Stopping LogMeIn Hamachi VPN tunneling engine logmein-hamachihamachid: no process found
stopping - success
Removing LogMeIn Hamachi service ..
Removing LogMeIn Hamachi symlink ..
Removing files from /opt/logmein-hamachi ..
LogMeIn Hamachi is removed.
pi-dragon6000@raspberrypi:~/logmein-hamachi-2.1.0.203-armel $ sudo ./install.sh
Copying files into /opt/logmein-hamachi ..
Creating LogMeIn Hamachi symlink ..
Creating TunTap ..
mknod: /dev/net/tun: File exists
Installing LogMeIn Hamachi service ..
Starting LogMeIn Hamachi service ..
starting - success
LogMeIn Hamachi is installed. See README for what to do next.
pi-dragon6000@raspberrypi:~/logmein-hamachi-2.1.0.203-armel $ /etc/init.d/logmein-hamachi start
starting - success
pi-dragon6000@raspberrypi:~/logmein-hamachi-2.1.0.203-armel $ sudo hamachi login
pi-dragon6000@raspberrypi:~/logmein-hamachi-2.1.0.203-armel $ ls
CHANGES dnsup hamachi-init LICENSE Release_notes.rtf
dnsdown hamachid install.sh README uninstall.sh
Hopefully all this information helps!
What should I do?
***Edit: I went to the place where I think the symbolic link was likely pointing: ~/opt/logmein-hamachi/bin and found the following files in that folder:dnsdown dnsup hamachid.
When trying to run hamachid it gave another "does not exist error". So perhaps it's not a problem with the link-file, but rather a problem with the actual hamachid file.
