I finally managed to make wlan0 (an Edimax EW-7811Un USB WiFi dongle) connect to my router, but after an apt-get update I discovered that my Raspberry can't connect outside the local network. The Raspberry is running on the latest (as of writing this) Raspbian image.
- wlan0 is connected to my router and has been given an IP address
- I can ping my router, my printer, and other machines inside the local network, but I can't ping anything in the outside net (also loopback ping on localhost says "host unreachable", but I'd say that it is NAT cancelling 127.0.0.1 requests)
- I can successfully connect through eth0, but I need to connect throughwlan0.
ifconfig output:
pi@MinoPi ~ $ ifconfig wlan0
wlan0     Link encap:Ethernet  HWaddr *macaddresshere*
      inet addr:192.168.1.9  Bcast:192.168.1.255  Mask:255.255.255.0
      UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
      RX packets:552 errors:0 dropped:6 overruns:0 frame:0
      TX packets:289 errors:0 dropped:0 overruns:0 carrier:0
      collisions:0 txqueuelen:1000
      RX bytes:375003 (366.2 KiB)  TX bytes:318051 (310.5 KiB)
iwconfig output:
pi@MinoPi ~ $ iwconfig wlan0
wlan0     IEEE 802.11bg  ESSID:"Sanctuary"  Nickname:"<WIFI@REALTEK>"
      Mode:Managed  Frequency:2.437 GHz  Access Point: *macaddresshere*
      Bit Rate:54 Mb/s   Sensitivity:0/0
      Retry:off   RTS thr:off   Fragment thr:off
      Power Management:off
      Link Quality=100/100  Signal level=100/100  Noise level=0/100
      Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0
      Tx excessive retries:0  Invalid misc:0   Missed beacon:0
/etc/network/interfaces file:
auto lo
iface lo inet loopback
iface eth0 inet dhcp
iface wlan0 inet static
    address 192.168.1.9
    netmask 255.255.255.0
    gateway 192.168.1.1
    wpa-ssid "Sanctuary"
    wpa-psk "somePasswordHere"
Any ideas?
ip route(man ip). – Błażej Michalik Aug 20 '16 at 15:50
