Experiencing external SSD data corruption issues which I believe are related to power issues.
Evaluating if it’s worth upgrading power supply from official Raspberry Pi 3A USB-C power supply to Argon Forty’s 3.5A USB-C power supply.
A Pi 4 shouldn't consume more than say 500-800mA (Reduce power consumption Raspberry PI 4) by itself, so I don't think your problem is with the power supply (unless of course it is a low quality one where voltages float around).
Corruption has other causes like for example SD card corruption
Assuming that you are actually having power problems, and not problems with a poor quality or worn out SD card...
Power problems could be caused by:
A higher voltage will not fix any of the above problems.
