-1
I'm trying to setup an automated backup system to backup my Raspberry Pi's data to my Mac Mini. However, calling neither borg init nor borg create from the RPi to the remote Mac Mini repo host seems to reach the borg server running on the Mac Mini. On the Mac Mini:
% sudo borg serve --debug --restrict-to-path /Users/borg/BorgRepos/RetroPie
$LOG DEBUG borg.logger Remote: using builtin fallback logging configuration
$LOG DEBUG borg.archiver Remote: 33 self tests completed in 0.12 seconds
On the RPi:
$ sudo borg create --debug --stats borg@octolen:/Users/borg/BorgRepos/RetroPie2::Friday2 RetroPie
35 self tests completed in 0.59 seconds
SSH command line: ['ssh', 'borg@octolen', 'borg', 'serve', '--umask=077', '--debug']
Password:
Remote: zsh:1: command not found: borg
Connection closed by remote host. Is borg working on the server?
File "/usr/lib/python3/dist-packages/borg/archiver.py", line 4455, in main
exit_code = archiver.run(args)
File "/usr/lib/python3/dist-packages/borg/archiver.py", line 4387, in run
return set_ec(func(args))
File "/usr/lib/python3/dist-packages/borg/archiver.py", line 134, in wrapper
make_parent_dirs=make_parent_dirs, args=args)
File "/usr/lib/python3/dist-packages/borg/remote.py", line 577, in __init__
raise ConnectionClosedWithHint('Is borg working on the server?') from None
borg.remote.ConnectionClosedWithHint: Connection closed by remote host. Is borg working on the server?
Platform: Linux retropie2 5.10.103-v7l+ #1529 SMP Tue Mar 8 12:24:00 GMT 2022 armv7l
Linux: debian 10.13
Borg: 1.1.9 Python: CPython 3.7.3
PID: 28539 CWD: /home/pi
sys.argv: ['/usr/bin/borg', 'create', '--debug', '--stats', 'borg@octolen:/Users/borg/BorgRepos/RetroPie2::Friday2', 'RetroPie']
SSH_ORIGINAL_COMMAND: None
I did add /usr/bin/borg to the Mac's firewall's list of applications permitted to allow incoming connections. What am I missing here?
fpt
  • 99
    your question does not belong here ... it is not about Raspberry Pi ... it is a linux question at best – jsotola Dec 24 '22 at 19:25
    Sure, it is. I want to back up my Raspberry Pi. How do you back up your Raspberry Pi? – fpt Dec 24 '22 at 19:32
  • you want to back up your linux computer... if you ran Linux on an HP computer, would you ask the question at an HP site? – jsotola Dec 24 '22 at 19:52
  • So then provide an insightful and practical answer here: https://unix.stackexchange.com/questions/729540/is-borg-working-on-the-server?noredirect=1#comment1383382_729540 – fpt Dec 25 '22 at 01:37
    Labeling this question as "off-topic" seems to abandon a long-standing precedent. There are numerous questions here on RPi SE that involve backup solutions. The OP's stated objective: setup an automated backup system to backup my Raspberry Pi's data. That sounds very Pi-specific to me. I don't understand his choice of borg, but that should not result in closure. – Seamus Dec 25 '22 at 06:20
  • @Seamus Thank you! I'm not wedded to borg. What would you suggest for backing up a RPi? I like incrementalistm, de-duplication, and compression in backup SW. – fpt Dec 25 '22 at 17:47
    My recommendation is in my answer below. – Seamus Dec 25 '22 at 23:22
  • Hello @fpt!!! I've closed the question as it isn't specifically related to the Pi. If Seamus has answered your question, (which I think they have), you can mark it as correct. – Darth Vader Dec 26 '22 at 11:23
  • I found a satisfactory answer to my question. Please reopen the question so I may post it. – fpt Dec 28 '22 at 04:19
The Objective: setup an automated backup system to backup my Raspberry Pi's data
I don't know anything about "borg", so this answer will address the objective. If "borg" is a requirement, you can stop reading here.
There is a backup solution that is specific for the RPi called image-backup. It's been around for a while, it is well-supported by the author, and it is easily automated. I have automated my backups using image-backup with a very simple script I schedule as a cron job from my RPi.
There have been several Q&A here on RPi SE that reference it (for example], or you can do your own search.
In my case, I create a "new-from-scratch" backup image every 4-8 weeks, and then update this "master" image using a script I run from the root crontab. I have placed all the image-backup scripts in /usr/local/sbin.
I update my backup images using the following script (also kept in /usr/local/sbin):
#!/bin/bash
filename: updt_img_bkup.sh
bash script to update image-backup images
this script scheduled via root's crontab
image file name prototype:
/mnt/SynologyNAS/rpi_share/raspberrypi3b/20220715_Pi3B_imagebackup.img
IMG_ROOT_LOC=/mnt/SynologyNAS/rpi_share/ HOSTNM=$(cat /etc/hostname)/ IMG_TO_UPDT=$IMG_ROOT_LOC$HOSTNM$(ls -1tr $IMG_ROOT_LOC$HOSTNM | tail -n 1) # update the latest file BASE_NM=$(basename $IMG_TO_UPDT) LOG_LOCATION=/home/pi/imagebackup.log
DRY_RUN=1 # 0 ==> dry-run, 1 ==> update backup image
printf "====> begin log entry for $0 <====\n" printf "Commence $BASH_ARGV0 at datetime: $(date -u)\n"
Verify the image to be updated is available:
if [ ! -f $IMG_TO_UPDT ]; then printf "\nBACKUP FAILURE: ON $(date -u), $0 FOUND NO IMG FILE TO UPDATE
AT LOCATION $IMG_TO_UPDT\n" | tee -a /etc/issue.net $LOG_LOCATION exit 1 fi
if [ $DRY_RUN -ne 0 ]; then # Write an entry to the log: printf "$BASH_ARGV0 - begin update of backup image: $BASE_NM, date-time: $(date -u)\n" # Update the backup image with the 'image-backup' script: /usr/local/sbin/image-backup $IMG_TO_UPDT RTN_CODE=$? if [ $RTN_CODE -eq 0 ]; then # updated backup successful printf "RESULT: Succesful update of backup completed at: $(date -u)\n" printf "Updated backup image: $(ls -l $IMG_TO_UPDT)\n" else # updated backup failed printf "ERROR: image-backup RTN_CODE is $RTN_CODE; $BASH_ARGV0 FAILED to update $IMG_TO_UPDT\n" | tee -a /etc/issue.net fi else printf "DRY_RUN invoked; NO UPDATE on $IMG_TO_UPDT\n" printf "END DRY_RUN value is: $DRY_RUN\n" printf "ENDING DATE-TIME: $(date -u); script: $BASH_ARGV0\n" fi
One line in the root crontab runs the script above on a schedule. The crontab entry also creates a log. Here's how:
$ sudo crontab -e
add the following line:
0 13 * * 0,2,5 /usr/local/sbin/updt_img_bkup.sh >> /home/pi/imagebackup.log 2>&1
This can easily be adapted to a number of situations; I will leave it to you to get the backup image file (*.img) to your Mac Mini. The *.img file created in this way can be used to do a complete restoration of your system by burning it to an SD card, or it can be mounted in a Linux system for access to individual files. There are two partitions in the image file: a FAT partition whose root is /boot, and an ext4 filesystem whose root is /. /boot can be read and edited on your Mac, the ext4 partition cannot. If, for some reason, you need a backup of specific files that reside on the ext4 partition, I'd suggest you use rsync for that purpose.
Seamus
  • 21,900
  • 70
  • It looks like it's nice for creating and synchronizing a bootable image, which has its place. But what I'm really looking for is a backup system, not a data synchronizer. And by "backup system" I mean that a new archive is created with each run. This is desirable because if some undesirable change happens to my original data and then gets copied to backup, then I'll still have older archives to refer back to. That's why I want backup and not sync. – fpt Dec 28 '22 at 04:10
    @fpt: image-backup has the capability to do that. In fact, if you enter only sudo image-backup, you will get a "fresh" image; if you enter image-backup /path/to/existing/image, it will update that image. You may be thinking of a backup rotation scheme. image-backup does not implement a rotation scheme - it only does the backups. In my case, I make a "fresh" backup about every 3-4 weeks, and bi-weekly updates. – Seamus Dec 28 '22 at 04:32
There is no need to start "borg serve" manually on the repo server because the borg client invokes that command via ssh and then talks to it via stdin/stdout/stderr.
That means that borg is not in the PATH on the repo server (for the ssh session created by the borg client).
So, borg is NOT (yet) working on the server.
https://twitter.com/pi_stack/status/1606668460074958849 < hehe
borg 1.1.9 is rather old btw and only safe if it is a patched version (like in debian). check if you can get a more recent version (e.g. from debian backports).
    That was a good suggestion, but doesn't seem to've been the issue: Mac Mini:
    % echo $PATH
    /usr/local/bin/borg:/usr/local/bin:/usr/bin:/bin:/usr/sbin:/sbin:/Library/Apple/usr/bin```
    RPi:
    ```sudo borg create borg@octolen:/Users/borg/BorgRepos/RetroPie2::Friday2 RetroPie
    Password:
    Connection closed by remote host. Is borg working on the server?```
    – fpt Dec 24 '22 at 18:48
    The PATH in your user shell is not necessarily the same as in the borg environment.
    And if your remote says "command not found: borg", you maybe should not assume that your mac is lying to you. :-)
    – ThomasWaldmann Dec 24 '22 at 23:35
  • You mean like this? borg@Octolen ~ % env HOME=/Users/borg LANG=en_US.UTF-8 LOGNAME=borg OLDPWD=/Users/borg PATH=/usr/local/bin/borg:/usr/local/bin:/usr/bin:/bin:/usr/sbin:/sbin:/Library/Apple/usr/bin PWD=/Users/borg SHELL=/bin/zsh – fpt Dec 24 '22 at 23:59
  • So then how could I check and reconfigure the PATH variable for the environment in which I'm trying to execute borg? – fpt Dec 25 '22 at 01:40
