Would it be possible to turn a Pi + HDMI display into a USB monitor? The Pi with the monitor would act as a 2nd display.
(note that I'm not looking to avoid buying a USB monitor, I want to build an external gadget that incorporates a 2nd display)
I see that the Pi can act as a USB OTG "gadget"/device: https://gist.github.com/gbaman/50b6cca61dd1c3f88f41 But I don't see monitor listed.
I see that the PiKVM has chosen to incorporate hardware HDMI capture https://pikvm.org/ But this could be because USB monitors aren't supported at say, the bios screen, which is required for their use case.
Is it technically possible?
Do USB monitors require a special driver on Windows, or are they a standard USB class device?
What kind of code would have to be written on the Pi side to support this if it can't do it already?
This could be done with a phone, or separate components and a USB hub. But if a Pi could be turned into a USB monitor, it would bring few parts together.
– Richard Dec 11 '22 at 00:44
