I got my raspberry pi couple of days back and am looking to use my laptop for display, mouse and keyboard, I have heard that, it is possible through installing VNC server in Raspberry pi.
Can anyone please post a complete procedure for doing it and also frequently encountered problems while installing.
To control your RaspberryPI through VNC using another computer do this:
Inside the RaspberryPi:
Install x11vnc:
$ sudo apt-get install x11vnc
Then, execute x11vnc as follow to assign a password that must be used when connecting to your VNC server:
$ x11vnc -storepasswd
Enter VNC password:
Verify password:
Write password to /home/pi/.vnc/passwd?  [y]/n
Password written to: /home/pi/.vnc/passwd
Inside your other computer:
$ x11vnc_ssh pi@192.168.1.57:0
Here 192.168.1.57 should be the IP of your RaspberryPi. This will ask for a password, which is the same you assigned inside your RaspberryPi to the VNC server.
This is the expected result:
Screenshot from RPi + x11vnc
Note: In my case the x11vnc_ssh is too verbose, so much that I couldn't see the password prompt from the server. So I chose to "disable" the stderr like this:
x11vnc_ssh pi@192.168.1.57:0 2>/dev/null
Hope it helps.
DWilches
  • 195
Since Raspbian Pixel came out, it is now recommended to install the official RealVNC server using sudo apt-get install -y realvnc-vnc-server. This is much faster and has much better quality that x11vnc, because RealVNC is the company that made VNC in the first place.
sudo apt-get install tightvnc
Is probably your best bet. You'll need to be able to ssh into it, and this assumes you have the debian build also.
JJ Asghar
